My graphics card doesn't work anymore after a power outage
Solved
poupouche -
jumulka Posted messages 12057 Registration date   Status Member Last intervention   -
Bonjour, comme indiqué dans le titre, ma carte graphique (Radeon 580) ne fonctionne plus après une panne de courant, ce qui fait que je ne peux pas allumer mon PC avec cette carte. J'ai donc utilisé une ancienne carte graphique (Nvidia 770) et cela fonctionne. Pourriez-vous s'il vous plaît m'aider à réparer ma Radeon 580 ?
  1. fabul Posted messages 42325 Registration date   Status Moderator Last intervention   6 097
    Hello,
    aside from clearing the CMOS of your BIOS (see the manual), there aren’t many solutions.
    It might be dead.
  2. poupouche
    I already cleared the CMOS but nothing works.
  3. AgentMulder Posted messages 1103 Registration date   Status Member Last intervention   167
    Hello,
    If you already have proof that your Radeon 580 is dead since it works with the Nvidia 770, unfortunately, there's nothing more to be done for your Radeon.
    You can try it in another PC for a second opinion.
    You can inspect your card to see if there's a burnt component, but that won't bring it back to life, and even an electronics repairman likely won't be able to do much.
    If the power outage is due to EDF or an external element to your home, then your insurance may compensate you if you're covered. But that's really all that can be done.
  4. bendumont Posted messages 8 Status Member
    You might want to try to make a warranty claim, I think it could work.
    It all depends on the seller and if your card is still under warranty. If not, good luck buying a new graphics card; this is really not a good time!!
  5. poupouche
    Well, I guess I'm going to keep my Nvidia and buy a Radeon when the prices return to normal. I'm going to mark my question as resolved since there's nothing more to do. Rest in peace, my little Radeon of 6 months.
    1. jumulka Posted messages 12057 Registration date   Status Member Last intervention   4 617
      If she is only 6 months old, activate the warranty.
