Xiaomi Redmi Note 9 Pro power/battery issue
Falky -
bazfile Posted messages 58534 Registration date   Status Moderator Last intervention   -
Hello, my Note 9 Pro suddenly turned off when I had 6 or 7% battery left, and since then I can't turn it back on. Whenever I try to power it on or force a restart, the home screen (with the Redmi logo) lights up for a brief moment (half a second) and is replaced by the battery icon in the middle of the screen for a few seconds. When I charge it, the same battery icon appears in the middle of the screen but stays frozen (no sign of charging).
Can you help me?
  1. bazfile Posted messages 58534 Registration date   Status Moderator Last intervention   20 288
    Hello, let your battery charge for 1 or 2 hours and if it's still the same, have your battery tested by a professional who will change it if necessary.
    bazfile
    Moderator/Security Contributor.
    A hello, a response, a thank you are always appreciated.
    2
  2. Falky
    Hello, I had already charged it for more than an hour (longer than necessary for a full charge) but nothing worked, I spammed the forced restart about ten times without success. I just put it to charge and miraculously it seems to be charging normally (the battery icon is filling up)
    Thank you for your intervention.
    I will classify this topic as resolved if it turns on correctly once the battery is charged.
      OK I hope it will be fine, just so you know it could also be the charger.
