Ethernet connection issue "Network cable not connected"
Solved
Good evening everyone,
With fiber newly installed, I figured it was time to switch to Ethernet wiring. A wall outlet had been installed specifically about 5 years ago, but I never noticed it and thus never used it.
However, when I plug my PC cable into the wall outlet, nothing. In Network and Sharing Center, my local area connection shows "Network cable unplugged."
I did some searching on other topics, but I didn’t understand everything.
I have checked my devices in Device Manager; everything is up to date and enabled. I also tried turning the Ethernet connection on/off in the Network and Sharing Center.
Do you have any ideas where the problem might come from?
Thanks in advance and have a good evening/day! :)
Ben
  • Descending date
  1. Are we talking about RJ45 or not?
    Because in that case ADSL or fiber, it doesn't change anything; you just need one of these cables to be connected to this fiber modem and that's it.
    If the cable is too old, it will bottleneck the possible throughput from the modem.
    So it's convenient that it's already run in the walls, but it can have a negative effect on the throughput if it's too old.
    1. Hello,
      Yes, we’re indeed dealing with RJ45
      The cables are all new, though, and those in the wall have hardly ever been used!
    2. @Forcica77They are brand new, but you don’t know where they pass?
      If their appearance is new, that’s another matter; what matters is their "Category," especially if you have a fiber modem, you need very high-quality RJ45 to get the best possible speed.
      2.5Gb, 5Gb, 10Gb/s...
    3. @JeuneLFor your information,
      the bastard speeds 2.5 and 5 Mbit/s were invented to extend the life a little of old Cat5 cabling
