VLOOKUP issue on another workbook with a variable path
Lauhick
Posted messages
4
Status
Member
Paliora -
Paliora -
Hello everyone!
To explain my problem, I would like to search for a value in a different folder than the one containing my workbook and have the ability to mark on an assigned cell the name of the file I want to search in.
I have tried several possibilities such as using VLOOKUP with this formulation:
=VLOOKUP(B21; " 'C:\Users\NG7ABDE\Desktop\Dossier\[" & B26 & ".xlsx]Sheet1'!$1:$1048576
"; 2)
The problem is that it cannot create the path...
I also tried with the CONCATENATE function.
I have already managed to create this function with a macro, but my goal now is to do without it.
I hope you can help me! :)
Thank you in advance!
Configuration: Windows / Chrome 68.0.3440.75
"; 2)
1 answer
Hello
try with:
=VLOOKUP(B21, INDIRECT("'C:\Users\NG7ABDE\Desktop\Dossier\[" & B26 & ".xlsx]Sheet1'!$A1:$B1048576"), 2)
which should adjust to the workbook name in B26
crdlmnt
The quality of the response mainly depends on the clarity of the question, thank you!-
I may have made a mistake in the model
Check that what you write between the parentheses of INDIRECT corresponds exactly to the address you want to obtain (in text, with texts, signs, etc..)
for that write the entire part between these parentheses (without the INDIRECT code, but with all the quotes) in a cell outside the range, starting with the equal sign, check the resulting label, correct if necessary to get the right code
and then insert it into the formula
crdlmnt -
Yes, yes, I had already checked it like that and the result perfectly matches the expected result. To tell you, I even copied this result as a value and then copied it directly into my search matrix, and the function gave me the expected result.
It seems that Excel struggles to understand that this string of characters is a folder path when using a function. -
