TV LCD TECHNIQUE LED 3211DHDB en panne
faouzy003 Posted messages 3 Status Member -
HELLO,
I have a Technical LED 3211dhdb LCD TV, and when I turn it on, the blue light blinks 11 times and then turns off, leaving the screen black. I checked the capacitors on the power supply board, and they are not swollen. Can someone help me?
Thank you
  1. Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   12 207
    Hello,
    Try unplugging the power plug, wait for a quarter of an hour, and then plug it back in.
    If that doesn't work and if you have access to the menu, do a reset (factory settings) but you'll have to redo the whole installation.
    I call a spade a spade *
    *in French in the text
    1. Faouzy 003
      Thank you Andy31200, but my TV won't turn on; only the indicator light blinks, then it stays stable. The screen remains black, and when I try to turn it on again with the remote, only the indicator light reacts. I would like to know if there isn't a diode behind the malfunction?
  2. faouzy003 Posted messages 3 Status Member 1
    <translation>Can someone help me?</translation>
  3. faouzy003 Posted messages 3 Status Member 1
    Friends, I'm waiting for your comments. Thank you
