Sony Bravia TV red LED blinks 4 times
JIwa -
 arcturus -
Hello,
I have a Sony Bravia TV that won't turn on.
Description of the issue:
When I start the TV, the green light turns on and after a few seconds the red light blinks 4 times every 2 or 3 seconds (the screen remains black).
I wanted to know if anyone can help me troubleshoot my TV.
Regards.
Joel
  • 1
  • 2
  1. amigo
    This is an electrical overload problem with the TV protection circuit;
    The solution is very simple:
    You need to disconnect the power cable and connect the two prongs of the plug together for at least one hour to allow the protection circuit to discharge.
    415
    1. Alex > amijef Posted messages 5 Status Member
      Hello
      I have the same problem, the red LED blinks 5 times. Could you please explain this procedure (plugging and unplugging)? Thank you very much.
      15
    2. vivi81
      Thank you very much, thanks to you my TV is working perfectly again, thank you again, I avoided 260 euros for a repairman, thanks again.
      5
  • 1
  • 2
