Connect speakers to Ibiza Sound sound system
Eddy4343
Posted messages
4
Status
Estonian -
Estonian -
Hi everyone,
I own an Ibiza Sound PORT15VHF speaker system, and I would like to connect additional speakers.. However, when I connect a speaker, no sound comes out.
What are the steps to follow? Adjustments? Tips?
Thank you
Here is the link to the speaker system: https://www.conrad.fr/p/enceinte-pa-mobile-ibiza-sound-port15vhf-bluetooth-port15vhf-bluetooth-38-cm-15-pouces-1-pcs-090858
(connection to - DC 12V + )
Thank you
The connector marked "DC 12v"... is not meant to connect a speaker but to connect an external battery! (Definitely not!) This connector does indeed resemble an old "wire clamp" for passive speakers, but not at all! It is for a 12-volt input as indicated. DC 12v (12 volts direct current).
