Problem with USB player with IBIZA speaker
Artistepro -
mushu14 Posted messages 11897 Registration date   Status Contributor Last intervention   -
Hello
I have an IBIZA BOOST80VHF-BT speaker. I'm very satisfied with it, but the USB playback mode stopped working properly quite quickly. The player searches for the tracks to play and either doesn't find them or finds them after a long waiting period. Would you have the firmware update software so that I can fix it and let me know how to do it? Thank you in advance for your help. Best regards.
  1. STARGATE43 Posted messages 13754 Registration date   Status Contributor Last intervention   2 648
    Hello,
    Do you have the manual for this speaker?
    Best regards ;-)
    --> NO PROBLEMS, ONLY SOLUTIONS <--
    What is fidelity? It's just a lack of opportunities;-)
    1. Artistepro
      No, I don't have it anymore...
  2. Jojolaguitare Posted messages 12012 Registration date   Status Member Last intervention   2 783
    Hello.
    Undoubtedly this notice. Well... a one in two chance!
    https://fc.darty.com/notices/DOCUMENTATION/2014/44/4028309_NOTCOMP.pdf
    See you...
    There is no point in running; you must leave on time...
    1. Artistepro
      Thank you very much, but it is of no use to me. My problem is not that I don't know how to use it. My problem is that the scanner of the USB reader won't recognize an MP3 file that is on the USB drive...
  3. mushu14 Posted messages 11897 Registration date   Status Contributor Last intervention   1 123
    Hi,
    have you tried formatting your key and putting some music back on it?
    the return II
    1. Artistepro
      Yes, I did it. I've tried everything; it really is the scanner of the USB reader that doesn't fix on any PM3, even if there's only one on the key.
    2. mushu14 Posted messages 11897 Registration date   Status Contributor Last intervention   1 123
      formatted in FAT32?
    3. Artistepro
      I don't know. I don’t know this term. Formatted key, new mp3, and there you go!
    4. Artistepro
      I’m telling you again, it’s not my fault! It’s the reader’s scanner that can’t find anything.
    5. mushu14 Posted messages 11897 Registration date   Status Contributor Last intervention   1 123
      I repeat, it's not my fault! It's the reader's scanner that finds nothing.
      In that case, if you're sure of your facts, what do you think we can do about it?
      We're not magicians, and your "reader scanner" doesn't need any firmware; everything is integrated internally.
      If anything, talk to the chip manufacturer of the "reader scanner," but we can't help you.
      As for me, it's goodbye.
