My computer connects via cable but not via Wi-Fi.
Solved
Tss69 Posted messages 141 Registration date   Status Member Last intervention   -
Hello,
My laptop has been connected via Ethernet cable since I acquired it. But I want to change and switch to Wi-Fi. The problem is that when I connect to my Wi-Fi network, it doesn't work. It remains on identifying and below it says "no internet access."
Could you please help me?
Thank you in advance.
Configuration: Samsung RV515 Laptop, Windows 7, Google Chrome
  1. kendomg Posted messages 32 Registration date   Status Member Last intervention   25
    Hi, first you need to check if your Wi-Fi card is set to "Obtain IPv4 address automatically," then go to your router and press the sync button so that the router can accept your laptop... Of course, this also means that you should have configured the Wi-Fi on your router before this step. ;)
    15
