Connect car radio directly to subwoofer
Solved
JolieLili
Richh -
Richh -
Hello, I have a Pioneer DEH3200UB car radio http://www.pioneer.eu/be/products/22/121/61/DEH-3200UB/index.html
with a preamp output for a sub, I have a Focal Snow 150 Wrms subwoofer http://www.feuvert.fr/caissons/focal-caisson-focal-sb-20-snow/p1002.html
and I would like to know how to make all of this work! I don't know what type of wire I need and where to connect it, yes I am blonde, well...
Thank you for your response.
Best regards, Allison
9 réponses
Yes, I was told that it wouldn't produce good bass, but I wanted to test it anyway, oh well ^^ Otherwise, I have an Alpine MRP F242 amplifier https://www.caraudiocentre.co.uk/product_m-alpine-car-audio-systems-mrp-f242_p-22456.htm but I don't know if it's good enough for the subwoofer, I just want to connect the amplifier to the subwoofer, not the speakers.
ricoo_d
Posted messages
703
Registration date
Status
Last intervention
136
your amp will be just enough without being at the "top" for your subwoofer. but your sound will be much better than if you connected your subwoofer to your car radio.
