Issue with Speed Dial
Solved
konoha_united
Posted messages
122
Status
Member
ILBRAN -
ILBRAN -
Hello, hello
Three or four days ago, I installed a new application on Firefox (something to play Mario, ...). And I wanted to remove that application. The problem is that I went to
Tools --> Options --> Restore default configuration.
My homepage has become Google, whereas originally, it was Speed Dial (an interface to browse your favorites faster). I couldn't set Speed Dial as my homepage again. I uninstalled the application and thought that by reinstalling it, it would automatically be on my homepage. But unfortunately, that's not the case... I'm stuck on Google... so how can I set the Speed Dial application as my homepage?
Thank you :)
Configuration: Windows Vista / Firefox 3.6.3
Thank you :)
Hello,
I know it's not very appreciated to wake up old posts, but having encountered this problem, this post pointed me in the right direction without providing the explanation. I found it:
- In the "Advanced" tab, you need to click on the settings button at the bottom left of the window that opens.
- Click on "First setup" and check the box "set speed dial as homepage." This writes the following link in Internet options, homepage zone: chrome://speeddial/content/speeddial.xul
There you go, I hope I was helpful in wrapping up this post.
Best regards,
Kostrovit -
Hello,
You need to reinstall this add-on: https://addons.mozilla.org/en-US/firefox/addon/4810
See you later
"Reason and logic can do nothing against stubbornness and folly." -
Thank you for your response :)
The problem is, I still don't have speed dial as my home page... I installed the add-on, but when I click on Firefox, it goes directly to Google. -
re,
In fact, when you install it, you need to check the box:
"Set Speed Dial as home page"
See you +
“Reason and logic can do nothing against stubbornness and foolishness.” -
Yeah, it's done, I figured out how to do it by searching through the options.
Thanks anyway for your suggestions. -
Sure, great, can you provide the steps to take in the options, so your topic can help others in your situation, thank you ;-)
Have a nice evening
“Reason and logic can do nothing against stubbornness and stupidity.”-
I agree with Kalimusic, if we found it, it's good to say so, but it's better to share it with friends.
I had the same problem, which I ended up solving like this: in the speed dial options (by clicking on the button in the toolbar) and opening the settings (at the bottom left) I successively clicked on:
- export settings
- restore default settings
- first setup / set speed dial as the default page
Then I relaunched firefox, which opened on a blank speed dial page
I then imported my saved settings, and everything is now perfect, firefox opens on my speed dial groups
Laurent
