La batterie du système est faible... que faire ?
Solved
Cyrano75 Posted messages 90 Status Member -
 Lhouss -
Hello,
for some time now, my PC has been displaying "System battery is low" at every startup, then it offers me either to ignore it by pressing F1, or "Run setup utility" by pressing F2.
I have already tried to enter by pressing F2, but a window opens and being a new user, I'm afraid of messing things up.
Does anyone know what to do?
Please help me quickly!
Thanks in advance...
Cyrano75
  1. klowlead
    Hi!
    The battery on your motherboard must be worn out. Try replacing it; it doesn’t cost anything.
    If I were seeing this message, that’s what I would do.
    Be careful when removing the old battery so you don’t damage the holder. And when you put in the new battery, hold it by the sides; it’s not recommended to touch the top or bottom of a battery.
    Starting a PC without a battery or with a dead battery isn’t that serious; all it contains is the BIOS configuration. However, be aware that removing the battery resets the BIOS settings to default.
    Keep me updated,
    Lorraine
    51
    1. Lhouss
      Thank you very much, however I think the battery holder is damaged.
