How to strike out a diagram in Word or PowerPoint
hika
Raymond PENTIER Posted messages 58230 Registration date Status Contributor Last intervention -
Good evening
I prepared a Word document in which I inserted some screenshots containing diagrams. There are some diagrams that are incorrect; I want to strike them through with a red cross to indicate that they are wrong.
Please help me to do this if it's possible with Word, otherwise with PowerPoint
Thank you
Thank you
use drawing icons
Be precise and complete in your questions, readers are not clairvoyants.
Search engines are here to help you. -
Which version? Office 2007 does not work like previous versions!
In the Word 2003 document, open the Drawing menu and insert a cross, which you can resize and change the color of as you wish, and then drag it wherever you want; then you will click "Format AutoShape" and choose the "In front of text" wrapping.
Retirement is great! Especially in the Caribbean... :-)
☻ Raymond ♂
