Analyse pour sKe69
merci davance danalyser mon rapport
Scan saved at 17:08:03, on 12/12/2008
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
D:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\avp.exe
D:\Program Files\Java\jre6\bin\jqs.exe
D:\Program Files\Internet Download Manager\IDMan.exe
C:\WINDOWS\system32\wbem\wmiapsrv.exe
C:\Program Files\MSN Messenger\usnsvc.exe
C:\Program Files\Internet Explorer\iexplore.exe
D:\Program Files\ManyCam 2.3\ManyCam.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\WINDOWS\system32\rsvp.exe
D:\Program Files\Mozilla Firefox\firefox.exe
C:\Documents and Settings\Administrateur\Mes documents\Downloads\Programs\HiJackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.google.fr/toolbar/ie8/sidebar.html
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = https://www.google.fr/?gws_rd=ssl
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = https://www.google.fr/?gws_rd=ssl
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = https://login.live.com/ppsecure/sha1auth.srf?lc=1036
O2 - BHO: IDM Helper - {0055C089-8582-441B-A0BF-17B458C2A3A8} - D:\Program Files\Internet Download Manager\IDMIECC.dll
O2 - BHO: MSIEPlugin - {4B0FAF5A-67C4-4625-AE07-B0DBADA16EBF} - (no file)
O2 - BHO: IEVkbdBHO - {59273AB4-E7D3-40F9-A1A8-6FA9CCA1862C} - D:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\ievkbd.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - D:\Program Files\Java\jre6\bin\ssv.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - D:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - D:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O4 - HKLM\..\Run: [AVP] "D:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\avp.exe"
O4 - HKCU\..\Run: [IDMan] d:\Program Files\Internet Download Manager\IDMan.exe /onboot
O8 - Extra context menu item: Ajouter à Kaspersky Anti-Banner - D:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\ie_banner_deny.htm
O8 - Extra context menu item: Download all links with IDM - D:\Program Files\Internet Download Manager\IEGetAll.htm
O8 - Extra context menu item: Download FLV video content with IDM - D:\Program Files\Internet Download Manager\IEGetVL.htm
O8 - Extra context menu item: Download with IDM - D:\Program Files\Internet Download Manager\IEExt.htm
O8 - Extra context menu item: E&xporter vers Microsoft Excel - res://C:\PROGRA~1\Microsoft Office\Office12\EXCEL.EXE/3000
O9 - Extra button: Statistiques de la protection du trafic Internet - {1F460357-8A94-4D71-9CA3-AA4ACF32ED8E} - D:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\SCIEPlgn.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\Microsoft Office\Office12\REFIEBAR.DLL
O16 - DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} (Checkers Class) - http://messenger.zone.msn.com/binary/msgrchkr.cab56986.cab
O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsPAClient.cab56907.cab
O16 - DPF: {F5A7706B-B9C0-4C89-A715-7A0C6B05DD48} (Minesweeper Flags Class) - http://messenger.zone.msn.com/binary/MineSweeper.cab56986.cab
O20 - AppInit_DLLs: D:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\mzvkbd.dll,D:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\adialhk.dll,D:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\kloehk.dll
O23 - Service: Adobe LM Service - Unknown owner - C:\Program Files\Fichiers communs\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Kaspersky Internet Security (AVP) - Kaspersky Lab - D:\Program Files\Kaspersky Lab\Kaspersky Internet Security 2009\avp.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - D:\Program Files\Java\jre6\bin\jqs.exe
End of file - 4629 bytes
Boot mode: Normal
Running processes:
Contributeur sécuritéSalut,
il est " désespérément " clean ce rapport ;)
Quels sont tes problèmes précisément ? ....
mon pc est tres long :'( je peux presque rien faire :'(
Contributeur sécuritéje peux presque rien faire
Précsie un peu plus stp ... c'est light comme explication ....
puis fais ceci :
Télécharge Random's System Information Tool (RSIT) de random/random et enregistre l'exécutable sur ton Bureau.
-> http://images.malwareremoval.com/random/RSIT.exe
! Ferme bien toutes tes applications en cours !
Double-clique sur " RSIT.exe " pour le lancer .
-> Une première fenêtre s'ouvre avec en titre : " Disclaimer of warranty " .
* Devant l'option "List files/folders created ..." , tu choisis : 2 months
* clique ensuite sur " Continue " pour lancer l'analyse ...
( Note : Si la dernière version de HijackThis n'est pas détectée sur ton PC, RSIT le téléchargera et te demandera d'accepter la licence.)
-> laisse faire le scan et ne touche pas au PC ...
Lorsque l'analyse sera terminée, deux fichiers texte s'ouvriront (probablement avec le bloc-note).
Poste le contenu de " log.txt " (c'est celui qui apparait à l'écran), ainsi que de " info.txt " (que tu verras dans la barre des tâches), pour analyse et attends la suite ...
Important : poste un rapport, puis l'autre dans la réponse suivante ... si tu essaies de poster les deux en même temps,
cela risque d'être trop long pour le forum ...
Et si "log.txt" seul, ne passe pas non plus , fais le en 2 fois ... merci ...
( Note : les rapports seront en outre sauvegardés dans ce dossier -> C:\rsit )
je le fait tous de suite merci beaucoup sKe69 tu est un pro :)
