Probleme d'importation java
c mon code
lors de compilation il affiche les erreur
merci pour toute reponce
c mon code
package tcpipattacker.modules;
import net.sourceforge.jpcap.capture.*;
import net.sourceforge.jpcap.net.*;
import tcpipattacker.*;
//import tcpipattacker.;
public class sniff
extends Module {
public String getName() {
return "sniff";
public String getHelp() {
return "SYNOPSIS : sniff\n" +
"DESCRIPTION : Sniff the network. This module is entirely assisted.\n" +
"Written by Julien CHABLE (jchable@itin.fr)\n";
public String run(String[] arguments) {
// Console d'affichage
Console console = new Console("sniff");
// Paramètres de la capture
int packetCount;
String filter = "";
String device;
try {
console.println("Instantiate Capturing Engine");
PacketCapture pcap = new PacketCapture();
console.println("Check for devices");
console.println("Available network devices on your machine :");
String[] devices = PacketCapture.lookupDevices();
// Affiche tous les accès réseau
for (int i = 0; i < devices.length; ++i)
console.println("\t " + i + " : " + devices[i]);
console.println("Use network device :");
device = pcap.findDevice();
console.println(device);
console.println("Open device to capturing (requires root)");
device=" \\Device\\NPF_{67A959FB-3D4C-463D-B1BD-92012FE5CDFE}";
pcap.open(device, true);
console.println("BPF filter (see pcap help) :");
//filter = console.prompt();
pcap.setFilter("", true);
console.println("Register a listener for packets");
pcap.addPacketListener(new PacketHandler());
console.println("How many packets to capture :");
packetCount = console.promptInt();
console.println("Capturing packets ...");
pcap.capture(1000);
catch (Exception e) {
return "Module " + getName() + " error : " + e.getMessage();
return "Succesfull execution of " + getName() + "!";
final class PacketHandler
implements PacketListener {
private String sourceAddress;
private String destinationAddress;
private String dataPacket;
private Console console = new Console();
public void packetArrived(Packet packet) {
try {
// Trame Ethernet
if (packet instanceof EthernetPacket) {
EthernetPacket ethernetPacket = (EthernetPacket) packet;
sourceAddress = ethernetPacket.getSourceHwAddress();
destinationAddress = ethernetPacket.getDestinationHwAddress();
console.println("[Ethernet] : from <" + sourceAddress + "> to <" +
destinationAddress + ">");
// Paquet ARP
if (packet instanceof ARPPacket) {
ARPPacket arpPacket = (ARPPacket) packet;
byte[] data = arpPacket.getARPHeader();
console.print("\t[ARP] : " +
(arpPacket.getOperation() == ARPFields.ARP_OP_REQ_CODE ?
"Request" : "Reply"));
console.print(" from " + arpPacket.getSourceProtoAddress() + " to " +
arpPacket.getDestinationProtoAddress());
console.println(" - Header length : " + arpPacket.getHeader().length +
" - Data Length : " + arpPacket.getData().length);
// Paquet IP
if (packet instanceof IPPacket) {
IPPacket ipPacket = (IPPacket) packet;
byte[] data = ipPacket.getIPData();
sourceAddress = ipPacket.getSourceAddress();
destinationAddress = ipPacket.getDestinationAddress();
dataPacket = new String(data, "ISO-8859-1");
console.println("\t[IP] : from <" + sourceAddress + "> to <" +
destinationAddress + ">\n\t\t" +
dataPacket);
// Paquet ICMP
if (packet instanceof ICMPPacket) {
ICMPPacket icmpPacket = (ICMPPacket) packet;
byte[] data = icmpPacket.getICMPData();
sourceAddress = icmpPacket.getSourceAddress();
destinationAddress = icmpPacket.getDestinationAddress();
console.println("\t[ICMP] : " +
ICMPMessage.getDescription(icmpPacket.getMessageCode()) +
"\n\t\tData : " + dataPacket);
// Paquet IGMP
if (packet instanceof IGMPPacket) {
IGMPPacket igmpPacket = (IGMPPacket) packet;
byte[] data = igmpPacket.getData();
sourceAddress = igmpPacket.getSourceAddress();
destinationAddress = igmpPacket.getDestinationAddress();
console.println("\t[IGMP] : " +
IGMPMessage.getDescription(igmpPacket.getMessageType()) +
" " + igmpPacket.getGroupAddress() + "\n\t\tData : " +
dataPacket);
// Paquet TCP
if (packet instanceof TCPPacket) {
TCPPacket tcpPacket = (TCPPacket) packet;
byte[] data = tcpPacket.getTCPData();
console.print("\t[TCP] - Port source : " +
String.valueOf(tcpPacket.getSourcePort()) +
" (" + IPPort.getName(tcpPacket.getSourcePort()) +
") Destination port : " +
String.valueOf(tcpPacket.getDestinationPort()) +
" (" + IPPort.getName(tcpPacket.getDestinationPort()) +
")\n\tSequence Number : " +
String.valueOf(tcpPacket.getSequenceNumber()) +
"\n\tAcknowledgment Number : " +
String.valueOf(tcpPacket.getAcknowledgmentNumber()) +
"\n\tHeader Length : " +
String.valueOf(tcpPacket.getTCPHeaderLength()));
// Flags
if (tcpPacket.isUrg())
console.println("\n\tURG[0x" + Integer.toHexString(tcpPacket.getUrgentPointer()) + "]");
if (tcpPacket.isAck())
console.println("\n\tACK[0x" + Long.toHexString(tcpPacket.getAcknowledgmentNumber()) + "]");
if (tcpPacket.isPsh())
console.println("\n\tPSH");
if (tcpPacket.isRst())
console.println("\n\tRST");
if (tcpPacket.isSyn())
console.println("\n\tSYN[0x" + Long.toHexString(tcpPacket.getSequenceNumber()) + "]");
if (tcpPacket.isFin())
console.println("\n\tFIN");
console.println("\tData : " + dataPacket);
// Paquet UDP
if (packet instanceof UDPPacket) {
UDPPacket udpPacket = (UDPPacket) packet;
byte[] data = udpPacket.getData();
console.print("\t[UDP] - Port source : " +
String.valueOf(udpPacket.getSourcePort()) +
" (" + IPPort.getName(udpPacket.getSourcePort()) +
String.valueOf(udpPacket.getDestinationPort()) +
" (" + IPPort.getName(udpPacket.getDestinationPort()));
console.println("");
e.printStackTrace();
"Compilation de TCP/IP Attacker en cours ..."
modules\sniff.java:7: cannot find symbol
symbol: class Module
extends Module {
modules\sniff.java:65: cannot find symbol
symbol : class Console
modules\sniff.java:21: cannot find symbol
5 errors
"Erreur de compilation !"
Press any key to continue . . .
Configuration: Windows XP Safari 525.13
Peut-être avec :
import tcpipattacker.modules.*;
Cordialement
Dan -
BONJOUR,
merci pour votre reponce
dans mon exemple tous les fichiers a importer se trouve directement sur tcpipattaker
mais je ne sais pas pourquoiil n'a pas les reconnu
en attandant d'autres soution et merci -
Re
même avec import tcpipattacker.Console; et import tcpipattacker.Module; ?-
Plus d'erreurs
"Compilation de TCP/IP Attacker en cours ..." modules\sniff.java:6: cannot find symbol symbol : class Console location: package tcpipattacker import tcpipattacker.Console; ^ modules\sniff.java:7: cannot find symbol symbol : class Module location: package tcpipattacker import tcpipattacker.Module; ^ modules\sniff.java:11: cannot find symbol symbol: class Module extends Module { ^ modules\sniff.java:69: cannot find symbol symbol : class Console location: class tcpipattacker.modules.PacketHandler private Console console = new Console(); ^ modules\sniff.java:25: cannot find symbol symbol : class Console location: class tcpipattacker.modules.sniff Console console = new Console("sniff"); ^ modules\sniff.java:25: cannot find symbol symbol : class Console location: class tcpipattacker.modules.sniff Console console = new Console("sniff"); ^ modules\sniff.java:69: cannot find symbol symbol : class Console location: class tcpipattacker.modules.PacketHandler private Console console = new Console(); ^ 7 errors "Erreur de compilation !" Press any key to continue . . . -
@samsoumatonC'est qu'on ne trouve ni la classe Console, ni la classe Module dans tcpipattacker (les autres erreurs sont les mêmes)
Tu as essayé import tcpipattacker.modules.Console; et import tcpipattacker.modules.Module; (ou .modules.*;)?
C MARCHE LE PROBLEME EST DS LA MANQUE DE BIBLIHOTEQUE
