Probleme modules pour GAIM
Comme je debute sur Linux (et oui encore un), j'ai des problemes a installer Gaim.
Lors de l'installation, il m'indique qu'il me faut le module GTK >2.0, donc je l'ai telechargé mais celui-ci me demande le module GLIB pour son installation :( , bon je le telecharge aussi, ensuite il me demande le module ATK mais là, il ne veux rien savoir. voici le code:
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... found
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for ld used by GCC... /usr/i486-suse-linux/bin/ld
checking if the linker (/usr/i486-suse-linux/bin/ld) is GNU ld... yes
checking for /usr/i486-suse-linux/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependant libraries... pass_all
checking command to parse /usr/bin/nm -B output... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for ranlib... ranlib
checking for strip... strip
checking for objdir... .libs
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.lo... yes
checking if gcc supports -fno-rtti -fno-exceptions... yes
checking whether the linker (/usr/i486-suse-linux/bin/ld) supports shared libraries... yes
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking whether -lc should be explicitly linked in... no
creating libtool
checking for Win32... no
checking for aclocal flags...
checking for pkg-config... /usr/bin/pkg-config
checking for GLIB - version >= 2.0.0... no
*** Could not run GLIB test program, checking why...
*** The test program failed to compile or link. See the file config.log for the
*** exact error that occured. This usually means GLIB is incorrectly installed.
Please si vous sauriez m'aider pour pouvoir utiliser enfin GAIM!
Là je suis vraiment bloqué!:(
Merci d'avance.;)
  1. Salut perso j'ai laissé tomber gaim et j'utilise psi qui permet de prendre en charge msn, yahoo, icq:
    1) Télécharger psi: (psi-0.9-5mdk.i586.rpm)
    ftp://ftp-stud.fht-esslingen.de//pub/Mirrors/Mandrake-devel/contrib/i586
    2) Installer psi:
    Se placer dans le répertoire de téléchargement:
    urpmi psi-0.9-5mdk.i586.rpm
    3) Créer son compte jabber:
    account setup > add : choisir un pseudo
    cocher "register new account"
    mettre un ID = pseudochoisi@jabber.org
    puis choisir mot de passe et le confirmer
    si ça ne marche pas, essaie un autre pseudo.
    4) Paramétrer msn:
    Paramétrer msn:
    Browse services > Ton pseudo
    amessage.de et cliquer sur browse:
    tu as alors msn, ICQ et yahoo qui apparaissent:
    pour msn : double-clique sur msn gateway
    et après tu devrais y arriver:
    pseudo@msn.com ou pseudo@hotmail.com etc...
    tes contacts vont s'importer illico
    Pour tes contacts, valide les autorisations.
    5) Enfin, dans options,
    coche make rooster a tool-window et enable docklet
    psi s'intègre alors au systray comme msn le fait sur windows !
    presario2100.
