Problème game out minecraft modée
voici mon problème es que quelqu'un pourrait m'aider
2018-06-08 12:37:54,442 WARN Unable to instantiate org.fusesource.jansi.WindowsAnsiOutputStream
[12:37:54] [main/INFO] [LaunchWrapper]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLTweaker
[12:37:54] [main/INFO] [LaunchWrapper]: Using primary tweak class name net.minecraftforge.fml.common.launcher.FMLTweaker
[12:37:54] [main/INFO] [LaunchWrapper]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLTweaker
[12:37:54] [main/INFO] [FML]: Forge Mod Loader version 12.18.3.2185 for Minecraft 1.10.2 loading
[12:37:54] [main/INFO] [FML]: Java is Java HotSpot(TM) 64-Bit Server VM, version 1.8.0_171, running on Windows 10:amd64:10.0, installed at C:\Program Files\Java\jre1.8.0_171
[12:37:55] [main/WARN] [FML]: The coremod aroma1997.core.coremod.CoreMod does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[12:37:55] [main/INFO] [FML]: Loading tweaker guichaguri.betterfps.tweaker.BetterFpsTweaker from BetterFps-1.4.5-1.10.jar
2018-06-08 12:37:55,958 WARN Unable to instantiate org.fusesource.jansi.WindowsAnsiOutputStream
2018-06-08 12:37:55,989 WARN Unable to instantiate org.fusesource.jansi.WindowsAnsiOutputStream
[12:37:56] [main/WARN] [FML]: The coremod codechicken.lib.asm.CCLCorePlugin does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[12:37:56] [main/WARN] [FML]: The coremod cofh.asm.LoadingPlugin does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[12:37:56] [main/WARN] [FML]: The coremod team.chisel.ctm.client.asm.CTMCorePlugin does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[12:37:56] [main/WARN] [FML]: The coremod ic2.core.coremod.IC2core does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[12:37:56] [main/WARN] [FML]: The coremod invtweaks.forge.asm.FMLPlugin does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[12:37:56] [main/WARN] [FML]: The coremod com.creativemd.itemphysic.ItemPatchingLoader does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[12:37:57] [main/WARN] [FML]: The coremod openmods.core.OpenModsCorePlugin does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[12:37:58] [main/INFO] [LaunchWrapper]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLInjectionAndSortingTweaker
[12:37:58] [main/INFO] [LaunchWrapper]: Loading tweak class name guichaguri.betterfps.tweaker.BetterFpsTweaker
[12:37:58] [main/INFO] [LaunchWrapper]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLDeobfTweaker
[12:37:58] [main/INFO] [LaunchWrapper]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLInjectionAndSortingTweaker
[12:37:58] [main/INFO] [LaunchWrapper]: Calling tweak class net.minecraftforge.fml.relauncher.CoreModManager$FMLPluginWrapper
[12:38:00] [main/INFO] [FML]: Found valid fingerprint for Minecraft Forge. Certificate fingerprint e3c3d50c7c986df74c645c0ac54639741c90a557
[12:38:00] [main/INFO] [FML]: Found valid fingerprint for Minecraft. Certificate fingerprint cd99959656f753dc28d863b46769f7f8fbaefcfc
[12:38:00] [main/INFO] [LaunchWrapper]: Calling tweak class net.minecraftforge.fml.relauncher.CoreModManager$FMLPluginWrapper
[12:38:00] [main/INFO] [Aroma1997Core]: Finished data injection.
[12:38:00] [main/INFO] [IC2-core]: Loaded library EJML-core-0.26.jar.
Exception in thread "main" [12:38:00] [main/INFO] [STDERR]: [java.lang.ThreadGroup:uncaughtException:-1]: java.lang.NoClassDefFoundError: com/creativemd/itemphysic/ItemTransformer
[12:38:00] [main/INFO] [STDERR]: [java.lang.ThreadGroup:uncaughtException:-1]: at com.creativemd.itemphysic.ItemPatchingLoader.getASMTransformerClass(ItemPatchingLoader.java:18)
[12:38:00] [main/INFO] [STDERR]: [java.lang.ThreadGroup:uncaughtException:-1]: at net.minecraftforge.fml.relauncher.CoreModManager$FMLPluginWrapper.injectIntoClassLoader(CoreModManager.java:128)
[12:38:00] [main/INFO] [STDERR]: [java.lang.ThreadGroup:uncaughtException:-1]: at net.minecraft.launchwrapper.Launch.launch(Launch.java:115)
[12:38:00] [main/INFO] [STDERR]: [java.lang.ThreadGroup:uncaughtException:-1]: at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
[12:38:00] [main/INFO] [STDERR]: [java.lang.ThreadGroup:uncaughtException:-1]: Caused by: java.lang.ClassNotFoundException: com.creativemd.itemphysic.ItemTransformer
[12:38:00] [main/INFO] [STDERR]: [java.lang.ThreadGroup:uncaughtException:-1]: at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:191)
[12:38:00] [main/INFO] [STDERR]: [java.lang.ThreadGroup:uncaughtException:-1]: at java.lang.ClassLoader.loadClass(Unknown Source)
[12:38:00] [main/INFO] [STDERR]: [java.lang.ThreadGroup:uncaughtException:-1]: ... 4 more
[12:38:00] [main/INFO] [STDERR]: [java.lang.Throwable:printStackTrace:-1]: Caused by: java.lang.NoClassDefFoundError: com/creativemd/creativecore/transformer/CreativeTransformer
[12:38:00] [main/INFO] [STDERR]: [java.lang.Throwable:printStackTrace:-1]: at java.lang.ClassLoader.defineClass1(Native Method)
[12:38:00] [main/INFO] [STDERR]: [java.lang.Throwable:printStackTrace:-1]: at java.lang.ClassLoader.defineClass(Unknown Source)
[12:38:00] [main/INFO] [STDERR]: [java.lang.Throwable:printStackTrace:-1]: at java.security.SecureClassLoader.defineClass(Unknown Source)
[12:38:00] [main/INFO] [STDERR]: [java.lang.Throwable:printStackTrace:-1]: at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:182)
[12:38:00] [main/INFO] [STDERR]: [java.lang.Throwable:printStackTrace:-1]: ... 6 more
[12:38:00] [main/INFO] [STDERR]: [java.lang.Throwable:printStackTrace:-1]: Caused by: java.lang.ClassNotFoundException: com.creativemd.creativecore.transformer.CreativeTransformer
[12:38:00] [main/INFO] [STDERR]: [java.lang.Throwable:printStackTrace:-1]: at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:101)
[12:38:00] [main/INFO] [STDERR]: [java.lang.Throwable:printStackTrace:-1]: at java.lang.ClassLoader.loadClass(Unknown Source)
[12:38:00] [main/INFO] [STDERR]: [java.lang.Throwable:printStackTrace:-1]: ... 10 more
Ca veut dire que ton minecraft forge crash?
Quelle est ta config de ton pc?
