Probleme lancement minecraft 1.6.2
bonjour a tous et a toute, j'ai un problème lors du démarrage de mon minecraft premium . Voici le message d'erreur dans la console:
C:\Users\willou53\AppData\Roaming\.minecraft\libraries\net\sf\jopt-simple\jopt-simple\4.5\jopt-simple-4.5.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\codecjorbis\20101023\codecjorbis-20101023.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\codecwav\20101023\codecwav-20101023.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\libraryjavasound\20101123\libraryjavasound-20101123.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\librarylwjglopenal\20100824\librarylwjglopenal-20100824.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\soundsystem\20120107\soundsystem-20120107.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\argo\argo\2.25_fixed\argo-2.25_fixed.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\bouncycastle\bcprov-jdk15on\1.47\bcprov-jdk15on-1.47.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\google\guava\guava\14.0\guava-14.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\apache\commons\commons-lang3\3.1\commons-lang3-3.1.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\commons-io\commons-io\2.4\commons-io-2.4.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\net\java\jinput\jinput\2.0.5\jinput-2.0.5.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\net\java\jutils\jutils\1.0.0\jutils-1.0.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\google\code\gson\gson\2.2.2\gson-2.2.2.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl\2.9.0\lwjgl-2.9.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl_util\2.9.0\lwjgl_util-2.9.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2.jar net.minecraft.client.main.Main --username MRcobrat53 --session token:a6ce3388de9d4492a030933b6c95b15c:93d5fa256ddc4315a3584bf46462c5f8 --version 1.6.2 --gameDir C:\Users\willou53\AppData\Roaming\.minecraft --assetsDir C:\Users\willou53\AppData\Roaming\.minecraft\assets
Client> 2013-09-08 01:23:10 [CLIENT] [INFO] Setting user: MRcobrat53
Client> 2013-09-08 01:23:10 [CLIENT] [INFO] (Session ID is token:a6ce3388de9d4492a030933b6c95b15c:93d5fa256ddc4315a3584bf46462c5f8)
Client> 2013-09-08 01:23:11 [CLIENT] [INFO] LWJGL Version: 2.9.0
Client> #
Client> # A fatal error has been detected by the Java Runtime Environment:
Client> #
Client> # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000006903d238, pid=2680, tid=4240
Client> #
Client> # JRE version: 7.0_25-b17
Client> # Java VM: Java HotSpot(TM) 64-Bit Server VM (23.25-b01 mixed mode windows-amd64 compressed oops)
Client> # Problematic frame:
Client> # C [atio6axx.dll+0xd238] DrvSwapBuffers+0xb8
Client> #
Client> # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
Client> #
Client> # An error report file with more information is saved as:
Client> # C:\Users\willou53\AppData\Roaming\.minecraft\hs_err_pid2680.log
Client> #
Client> # If you would like to submit a bug report, please visit:
Client> # https://bugreport.java.com/bugreport/crash.jsp
Client> # The crash happened outside the Java Virtual Machine in native code.
Client> # See problematic frame for where to report the bug.
Client> #
Game ended with bad state (exit code 1)
Ignoring visibility rule and showing launcher due to a game crash
Deleting C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2-natives-12523455202815
Couldn't delete C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2-natives-12523455202815 - scheduling for deletion upon exit
merci de bien vouloir m'aider.
  1. il fau avoir la derniere versin de java
    1. J'ai java jre7 update 25
      1. j'ai réinstaller java jre7 update 25 et vérifier sur le site que elle était bien installer mais un nouveau message d'erreur apparaît :
        Launching game
        Looking for old natives to clean up...
        Unpacking natives to C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2-natives-53746793006163
        Launching in C:\Users\willou53\AppData\Roaming\.minecraft
        Running C:\Program Files\Java\jre7\bin\javaw.exe -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -Djava.library.path=C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2-natives-53746793006163 -cp C:\Users\willou53\AppData\Roaming\.minecraft\libraries\net\sf\jopt-simple\jopt-simple\4.5\jopt-simple-4.5.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\codecjorbis\20101023\codecjorbis-20101023.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\codecwav\20101023\codecwav-20101023.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\libraryjavasound\20101123\libraryjavasound-20101123.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\librarylwjglopenal\20100824\librarylwjglopenal-20100824.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\soundsystem\20120107\soundsystem-20120107.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\argo\argo\2.25_fixed\argo-2.25_fixed.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\bouncycastle\bcprov-jdk15on\1.47\bcprov-jdk15on-1.47.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\google\guava\guava\14.0\guava-14.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\apache\commons\commons-lang3\3.1\commons-lang3-3.1.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\commons-io\commons-io\2.4\commons-io-2.4.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\net\java\jinput\jinput\2.0.5\jinput-2.0.5.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\net\java\jutils\jutils\1.0.0\jutils-1.0.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\google\code\gson\gson\2.2.2\gson-2.2.2.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl\2.9.0\lwjgl-2.9.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl_util\2.9.0\lwjgl_util-2.9.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2.jar net.minecraft.client.main.Main --username MRcobrat53 --session token:222b4a7e090940458f23d44b294bbdca:93d5fa256ddc4315a3584bf46462c5f8 --version 1.6.2 --gameDir C:\Users\willou53\AppData\Roaming\.minecraft --assetsDir C:\Users\willou53\AppData\Roaming\.minecraft\assets
        Client> 2013-09-08 12:50:23 [CLIENT] [INFO] Setting user: MRcobrat53
        Client> 2013-09-08 12:50:23 [CLIENT] [INFO] (Session ID is token:222b4a7e090940458f23d44b294bbdca:93d5fa256ddc4315a3584bf46462c5f8)
        Client> 2013-09-08 12:50:24 [CLIENT] [INFO] LWJGL Version: 2.9.0
        Client> #
        Client> #
        Client> # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000006903d238, pid=2016, tid=2836
        Client> #
        Client> #
        Client> #
        Client> # C:\Users\willou53\AppData\Roaming\.minecraft\hs_err_pid2016.log
        Client> #
        Client> #
        Deleting C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2-natives-53746793006163
        1. j'ai résolue le problème en mettant a jour ma carte graphic mais le problème ai que cette mis a jour j'ai déjà essayer de la faire mais plantais lors de l'installations sinon c'est réussi merci de ma voir aider je vais pouvoir profiter de se cadeaux :)
