Probleme lancement minecraft 1.6.2
bonjour a tous et a toute, j'ai un problème lors du démarrage de mon minecraft premium . Voici le message d'erreur dans la console:
C:\Users\willou53\AppData\Roaming\.minecraft\libraries\net\sf\jopt-simple\jopt-simple\4.5\jopt-simple-4.5.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\codecjorbis\20101023\codecjorbis-20101023.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\codecwav\20101023\codecwav-20101023.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\libraryjavasound\20101123\libraryjavasound-20101123.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\librarylwjglopenal\20100824\librarylwjglopenal-20100824.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\soundsystem\20120107\soundsystem-20120107.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\argo\argo\2.25_fixed\argo-2.25_fixed.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\bouncycastle\bcprov-jdk15on\1.47\bcprov-jdk15on-1.47.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\google\guava\guava\14.0\guava-14.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\apache\commons\commons-lang3\3.1\commons-lang3-3.1.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\commons-io\commons-io\2.4\commons-io-2.4.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\net\java\jinput\jinput\2.0.5\jinput-2.0.5.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\net\java\jutils\jutils\1.0.0\jutils-1.0.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\google\code\gson\gson\2.2.2\gson-2.2.2.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl\2.9.0\lwjgl-2.9.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl_util\2.9.0\lwjgl_util-2.9.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2.jar net.minecraft.client.main.Main --username MRcobrat53 --session token:a6ce3388de9d4492a030933b6c95b15c:93d5fa256ddc4315a3584bf46462c5f8 --version 1.6.2 --gameDir C:\Users\willou53\AppData\Roaming\.minecraft --assetsDir C:\Users\willou53\AppData\Roaming\.minecraft\assets
Client> 2013-09-08 01:23:10 [CLIENT] [INFO] Setting user: MRcobrat53
Client> 2013-09-08 01:23:10 [CLIENT] [INFO] (Session ID is token:a6ce3388de9d4492a030933b6c95b15c:93d5fa256ddc4315a3584bf46462c5f8)
Client> 2013-09-08 01:23:11 [CLIENT] [INFO] LWJGL Version: 2.9.0
Client> #
Client> # A fatal error has been detected by the Java Runtime Environment:
Client> #
Client> # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000006903d238, pid=2680, tid=4240
Client> #
Client> # JRE version: 7.0_25-b17
Client> # Java VM: Java HotSpot(TM) 64-Bit Server VM (23.25-b01 mixed mode windows-amd64 compressed oops)
Client> # Problematic frame:
Client> # C [atio6axx.dll+0xd238] DrvSwapBuffers+0xb8
Client> #
Client> # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
Client> #
Client> # An error report file with more information is saved as:
Client> # C:\Users\willou53\AppData\Roaming\.minecraft\hs_err_pid2680.log
Client> #
Client> # If you would like to submit a bug report, please visit:
Client> # https://bugreport.java.com/bugreport/crash.jsp
Client> # The crash happened outside the Java Virtual Machine in native code.
Client> # See problematic frame for where to report the bug.
Client> #
Game ended with bad state (exit code 1)
Ignoring visibility rule and showing launcher due to a game crash
Deleting C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2-natives-12523455202815
Couldn't delete C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2-natives-12523455202815 - scheduling for deletion upon exit
merci de bien vouloir m'aider.
Client> #
Client> #
Client> #
Client> #
Client> #
Client> #
Client> #
j'ai résolue le problème en mettant a jour ma carte graphic mais le problème ai que cette mis a jour j'ai déjà essayer de la faire mais plantais lors de l'installations sinon c'est réussi merci de ma voir aider je vais pouvoir profiter de se cadeaux :)
j'ai réinstaller java jre7 update 25 et vérifier sur le site que elle était bien installer mais un nouveau message d'erreur apparaît :
Launching game
Looking for old natives to clean up...
Unpacking natives to C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2-natives-53746793006163
Launching in C:\Users\willou53\AppData\Roaming\.minecraft
Running C:\Program Files\Java\jre7\bin\javaw.exe -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -Djava.library.path=C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2-natives-53746793006163 -cp C:\Users\willou53\AppData\Roaming\.minecraft\libraries\net\sf\jopt-simple\jopt-simple\4.5\jopt-simple-4.5.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\codecjorbis\20101023\codecjorbis-20101023.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\codecwav\20101023\codecwav-20101023.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\libraryjavasound\20101123\libraryjavasound-20101123.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\librarylwjglopenal\20100824\librarylwjglopenal-20100824.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\paulscode\soundsystem\20120107\soundsystem-20120107.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\argo\argo\2.25_fixed\argo-2.25_fixed.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\bouncycastle\bcprov-jdk15on\1.47\bcprov-jdk15on-1.47.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\google\guava\guava\14.0\guava-14.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\apache\commons\commons-lang3\3.1\commons-lang3-3.1.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\commons-io\commons-io\2.4\commons-io-2.4.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\net\java\jinput\jinput\2.0.5\jinput-2.0.5.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\net\java\jutils\jutils\1.0.0\jutils-1.0.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\com\google\code\gson\gson\2.2.2\gson-2.2.2.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl\2.9.0\lwjgl-2.9.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\libraries\org\lwjgl\lwjgl\lwjgl_util\2.9.0\lwjgl_util-2.9.0.jar;C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2.jar net.minecraft.client.main.Main --username MRcobrat53 --session token:222b4a7e090940458f23d44b294bbdca:93d5fa256ddc4315a3584bf46462c5f8 --version 1.6.2 --gameDir C:\Users\willou53\AppData\Roaming\.minecraft --assetsDir C:\Users\willou53\AppData\Roaming\.minecraft\assets
Client> 2013-09-08 12:50:23 [CLIENT] [INFO] Setting user: MRcobrat53
Client> 2013-09-08 12:50:23 [CLIENT] [INFO] (Session ID is token:222b4a7e090940458f23d44b294bbdca:93d5fa256ddc4315a3584bf46462c5f8)
Client> 2013-09-08 12:50:24 [CLIENT] [INFO] LWJGL Version: 2.9.0
Client> #
Client> #
Client> # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000006903d238, pid=2016, tid=2836
Client> #
Client> #
Client> #
Client> # C:\Users\willou53\AppData\Roaming\.minecraft\hs_err_pid2016.log
Client> #
Client> #
Deleting C:\Users\willou53\AppData\Roaming\.minecraft\versions\1.6.2\1.6.2-natives-53746793006163
J'ai java jre7 update 25
il fau avoir la derniere versin de java
