Probleme recuperation de variable $_SESSION
Je suis sous joomla et je n'arrive pas a recuperer le champ 'user' de la variable $_SESSION. Il me met
Dans mon code je l'apelle comme ca :
Lorsque je fait un print_r de la variable session il m'affiche ceci :
Notice: Undefined index: user in /home/site/www/administrator/components/com_comprofiler/view/view.users.php
print_t $_SESSION['user'];
Array
[__default] => Array
[session.counter] => 31
[session.timer.start] => 1318577082
[session.timer.last] => 1318577791
[session.timer.now] => 1318577802
[session.client.browser] => Mozilla/5.0 (Windows NT 6.1; WOW64; rv:7.0.1) Gecko/20100101 Firefox/7.0.1
[registry] => JRegistry Object
[_defaultNameSpace] => session
[_registry] => Array
[session] => Array
[data] => stdClass Object
[searchcom_comprofiler] =>
[viewcom_comprofilerlimitstart] => 0
[viewcom_comprofilerlastCBlist] => showusers
[application] => Array
[lang] =>
[com_cpanel] => Array
[mtupgrade] => stdClass Object
[checked] => 1
[_errors] => Array
[user] => JUser Object
[id] => 62
[name] => Administrator
[username] => admin
[email] => contact@site.com
[password] => 240b3331bea0cf7fb714caea7917e540:b3Asq2DL9eelbiHpOqB0ntBCwnDuQ52B
[password_clear] =>
[usertype] => Super Administrator
[block] => 0
[sendEmail] => 1
[gid] => 25
[registerDate] => 2011-03-08 16:24:24
[lastvisitDate] => 2011-10-11 16:04:19
[activation] =>
[params] =>
[aid] => 2
[guest] => 0
[_params] => JParameter Object
[_raw] =>
[_xml] =>
[_elements] => Array
[_elementPath] => Array
[0] => /home/site/www/libraries/joomla/html/parameter/element
[_defaultNameSpace] => _default
[_default] => Array
[_errors] => Array
[_errorMsg] =>
[_errors] => Array
[session.token] => 219b1ffd388a7575ef30c1a66e20927f
[id] => 62
[username] => admin
[password_clear] =>
[block] => 0
[sendEmail] => 1
[gid] => 25
[activation] =>
[params] =>
donc $_SESSION['user'] est un array il ne faut pas faire echo mais print_r
ou echo $_SESSION['user']['name'] par exemple -
je faisait bien un print_r. j'ai ecrit echo dans mon message par erreur.
Il me met toujours undefined index et je ne comprend pas pourquoi étant donner qu'il y a bien un array user.
Précision je suis en backoffice de joomla je ne sait pas si ça change quelque chose -
Si je ne me mêle pas les pinceaux, tu n'as pas de $_SESSION['user'] mais $_SESSION['__default']['user'] -
super c'est bien ca. merci
