Convertir des chiffres vers letttes
salut
j'ai realisé une aplication avec le gestionnaire d'atelier windev 7
mais le probléme si que je veux une fonction au un alogorithme qui fait convertir les chiffres vers des lettres
exmple:
10 dolar : dix dolar
4000 franc : quattre milles franc
merci d'avance
    c'est quoi la question ?
      J'ai trouvé une solution Visual Basic sur internet. Il convient de l'adapter à votre contexte.
      Dim EngNum(90) As String
      Dim StringNum As String, Chunk As String, English As String
      Dim Hundreds As Integer, Tens As Integer, Ones As Integer
      Dim LoopCount As Integer, StartVal As Integer
      Dim TensDone As Integer
      Dim Pennies As String
      Static Function NumWord(ByVal AmountPassed As Currency) As String
      '** Convert a number to words for filling in the Amount of a check
      '** Example: NumWord(120.45) returns ONE HUNDRED TWENTY AND 45/100
      '** Can handle numbers from 0 to $999,999.99
      '** Created by Alan Simpson: Fax (619)756-0159
      '** First working version, not yet fully tuned for speed or brevity.
      '** The array below, and other variables, are dimensioned
      '** in the Declarations section.
      '** Fill EngNum array, if it's not filled already)
      If Not EngNum(1) = "One" Then
      EngNum(0) = ""
      EngNum(1) = "One"
      EngNum(2) = "Two"
      EngNum(3) = "Three"
      EngNum(4) = "Four"
      EngNum(5) = "Five"
      EngNum(6) = "Six"
      EngNum(7) = "Seven"
      EngNum(8) = "Eight"
      EngNum(9) = "Nine"
      EngNum(10) = "Ten"
      EngNum(11) = "Eleven"
      EngNum(12) = "Twelve"
      EngNum(13) = "Thirteen"
      EngNum(14) = "Fourteen"
      EngNum(15) = "Fifteen"
      EngNum(16) = "Sixteen"
      EngNum(17) = "Seventeen"
      EngNum(18) = "Eighteen"
      EngNum(19) = "Nineteen"
      EngNum(20) = "Twenty"
      EngNum(30) = "Thirty"
      EngNum(40) = "Forty"
      EngNum(50) = "Fifty"
      EngNum(60) = "Sixty"
      EngNum(70) = "Seventy"
      EngNum(80) = "Eighty"
      EngNum(90) = "Ninety"
      End If
      '** Convert incoming Currency value to a string for parsing.
      StringNum = Format$(AmountPassed, "000000.00")
      '** Initialize other variables
      English = ""
      LoopCount = 1
      StartVal = 1
      Pennies = Mid$(StringNum, 8, 2)
      '** Just in case the check is for less than a buck...
      If AmountPassed < 1 Then
      English = "Zero"
      End If
      '** Now do each 3-digit section of number.
      While LoopCount <= 2
      Chunk = Mid$(StringNum, StartVal, 3)
      Hundreds = Val(Mid$(Chunk, 1, 1))
      Tens = Val(Mid$(Chunk, 2, 2))
      Ones = Val(Mid$(Chunk, 3, 1))
      '** Do the hundreds portion of 3-digit number
      If Val(Chunk) > 99 Then
      English = English & EngNum(Hundreds) & " Hundred "
      End If
      '** Do the tens & ones portion of 3-digit number
      TensDone = False
      '** Is it less than 10?
      If Tens < 10 Then
      English = English & " " & EngNum(Ones)
      TensDone = True
      End If
      '** Is it a teen?
      If (Tens >= 11 And Tens <= 19) Then
      English = English & EngNum(Tens)
      TensDone = True
      End If
      '** Is it Evenly Divisible by 10?
      If (Tens / 10#) = Int(Tens / 10#) Then
      TensDone = True
      End If
      '** Or is it none of the above?
      If Not TensDone Then
      English = English & EngNum((Int(Tens / 10)) * 10)
      End If
      '** Add the word "thousand" if necessary.
      If AmountPassed > 999.99 And LoopCount = 1 Then
      English = English + " Thousand "
      End If
      '** Do pass through second three digits
      LoopCount = LoopCount + 1
      StartVal = 4
      Wend
      '** Done: Return english with pennies tacked on.
      NumWord = Trim(English) & " and " & Pennies & "/100"
      End Function
      Bon courage, il y a du travail
      Cordialement
      1. convertir des chiffres vers lettte
