Probleme Grub et splashimage
Voilà j'essaye depuis quelques jours déjà d'installer une splashimage pour donner meilleure mine au grub. J'ai suivi pas mal de discussions sur les forums mais je n'ai pas trouvé de solution à mon probleme.
Au lancement du grub, j'ai le message "Failed to read splashimage ..."
Pourtant, lorsque j'execute la commande update-grub, il trouve bien la splashimage ... :
Searching for GRUB installation directory ... found: /boot/grub
Searching for default file ... found: /boot/grub/default
Testing for an existing GRUB menu.lst file ... found: /boot/grub/menu.lst
Searching for splash image ... found: hd(0,3)/boot/grub/splashimages/fiesta.xpm.gz
Found kernel: /boot/vmlinuz-2.6.22-14-generic
Found kernel: /boot/memtest86+.bin
Updating /boot/grub/menu.lst ... done
je passe aussi mon menu.lst :
# menu.lst - See: grub(8), info grub, update-grub(8)
# grub-install(8), grub-floppy(8),
# grub-md5-crypt, /usr/share/doc/grub
# and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not use 'savedefault' or your
# array will desync and will not let you boot your system.
default 4
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout 4
## hiddenmenu
# Hides the menu by default (press ESC to see the menu)
#hiddenmenu
# Pretty colours
#color cyan/blue white/blue
#Splashimages
splashimage=hd(0,3)/boot/grub/splashimages/fiesta.xpm.gz
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line) and entries protected by the
# command 'lock'
# e.g. password topsecret
# password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
# title Linux
# root (hd0,1)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
## kopt_2_6_8=root=/dev/hdc1 ro
## kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=UUID=079d4aed-7bab-43c4-9dc2-77df56d3eed3 ro
## Setup crashdump menu entries
## e.g. crashdump=1
# crashdump=0
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd0,3)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
## alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
## lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet splash
## should update-grub lock old automagic boot options
## e.g. lockold=false
## lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
## altoptions=(recovery) single
# altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
## howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
## memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## should update-grub add savedefault to the default options
# savedefault=false
## ## End Default Options ##
title Ubuntu 7.10, kernel 2.6.22-14-generic
root (hd0,3)
kernel /boot/vmlinuz-2.6.22-14-generic root=UUID=079d4aed-7bab-43c4-9dc2-77df56d3eed3 ro quiet splash
initrd /boot/initrd.img-2.6.22-14-generic
quiet
title Ubuntu 7.10, kernel 2.6.22-14-generic (recovery mode)
root (hd0,3)
kernel /boot/vmlinuz-2.6.22-14-generic root=UUID=079d4aed-7bab-43c4-9dc2-77df56d3eed3 ro single
title Ubuntu 7.10, memtest86+
root (hd0,3)
kernel /boot/memtest86+.bin
quiet
### END DEBIAN AUTOMAGIC KERNELS LIST
# This is a divider, added to separate the menu items below from the Debian
# ones.
title Other operating systems:
root
# This entry automatically added by the Debian installer for a non-linux OS
# on /dev/sda2
title Windows NT/2000/XP
root (hd0,1)
savedefault
makeactive
chainloader +1
J'utilise Xubuntu ...
Voili voilou merci d'avance
Elcockeros
## default num
default 4
## timeout sec
timeout 4
## hiddenmenu
#hiddenmenu
# Pretty colours
#Splashimages
# command 'lock'
# examples
# root (hd0,0)
# makeactive
# chainloader +1
# title Linux
# root (hd0,1)
## e.g. crashdump=1
# crashdump=0
# groot=(hd0,3)
# alternative=true
## alternatives
## lockold=true
# lockold=false
# xenhopt=
## e.g. howmany=all
## howmany=7
# howmany=all
## memtest86=false
# memtest86=true
# savedefault=false
root (hd0,3)
quiet
root (hd0,3)
root (hd0,3)
quiet
# ones.
root
# on /dev/sda2
root (hd0,1)
savedefault
makeactive
chainloader +1
Elcockeros
Configuration: Linux Firefox 2.0.0.6
Contributeurbonjour,
mets un # devant cette ligne
et tu n'aura plus le message
ensuite si tu veux mettre une image mets la au bon format .
a+
Les splashimages sont des fichiers zippés donc dézippe-les, copie-les par exemple dans /home/username/myfoldername et puis "mets en route" l'image (qui aura alors l'extension .xpm ) comme tu l'as fait pour le fichier zippé mis à part que le fichier zippé lui le Grub ne sait rien en faire.
