Unix Probleme
Je cherche à installer un script mais j'ai un probleme, ce script doit s'installer avec Unix je crois j'ai pas bien compris :
Installation
Basic requirements: A computer running a Unix or Unix-like OS(infinity has been specifically tested with and is known to work under Ubuntu 14.x), Apache, MySQL, and PHP
Make sure Apache has read/write access to the directory infinity resides in.
install.php is not maintained. Don't use it.
As of February 22, 2015, you need the DirectIO module (dio.so). This is for compatibility with NFS.
Step 1. Create infinity's database from the included install.sql file. Enter mysql and create an empty database named 'infinity'. Then cd into the infinity base directory and run:
mysql -uroot -p infinity < install.sql
echo '+ <a href="https://github.com/ctrlcctrlv/infinity">infinity</a> '`git rev-parse HEAD|head -c
Pouvez vous me dire comment faire ça en étant sur Windows.
Merci.
