Welltech universal remote control help
Solved
bigshow77
Posted messages
17
Status
Member
ismega -
ismega -
Hello,
I have had a Welltech remote control with 10 functions model 40085/HTFB85 for 3 days and I want to program my Grandin TV, but none of the codes work except for code 0169, which gives a mixed result since I cannot use the number keys (0-9), as well as the volume +/- and channel +/- keys (when I use them it takes me to channel 0). Moreover, channels 2-3-4-5 are programmed on the directional buttons. I need help or another code.
P.S.: My TV is second-hand, so there's no point in asking for the references as I don’t have them.
Thank you in advance for your help
Configuration: Windows XP Firefox 3.0.1
I have this remote control and despite everything, I can't manage to do it. Could someone tell me how to program the channels using this remote control?
The programming of channels does not depend solely on the remote control, but mainly on the television.
For the remote control, it is usually enough to press the Menu button (sometimes just M) to enter the settings. However,
- Some televisions require a more complex action, such as pressing two buttons simultaneously. It is necessary to have the TV manual to know this.
- It is relatively common that, despite entering a code that seems correct, certain functions are not supported by the remote control, even after trying several codes. There may be partial incompatibility between the TV and the remote control; this most often affects the Menu and/or AV buttons.
To err is human, to persist is diabolical.
