Samsung sv-dvd 3e problem help !!
maogani75 -
 scorpix -
Problem with my Samsung SV-DVD 3E combined unit
Help!!
Unable to switch to DVD (black screen)
Unable to display the menu for the "enter" function (black screen)
VHS function works normally in playback and direct recording (programming impossible since "enter" function is invisible)
Thank you for your advice and opinion.
  1. scorpix
    Hello, I also have a problem; mine is that when inserting a DVD, it loads "loading" indefinitely without ever starting the DVD. The optical drive was changed but the problem has occurred again a few months later.
    What is the problem?
    Thank you in advance.
    3
  2. baladur13 Posted messages 47406 Registration date   Status Moderator Last intervention   14 414
    Sorry, but I can't be of any use here, except for basic control...
    Still, check if we can do the manipulations directly on the VCR... just in case the remote might be defective.
    If that's the case, try changing the batteries in said remote...
    You can also try asking Samsung by email....
    But I think the solution lies in the intervention of a service center.... get a quote because sometimes it’s better to buy new than to repair.... (considering the prices charged)
    It is very difficult to catch a black cat in a dark room...
    Especially when it isn’t there...!!!!
  3. baladur13 Posted messages 47406 Registration date   Status Moderator Last intervention   14 414
    Hello Maogani
    Is it a magneto/DVD combo that you just installed or a malfunction that has just appeared???
    Just in case, here is the manual
    https://downloadcenter.samsung.com/content/UM/200304/20030412101617687_DVD3E-XEF-F.pdf
    It's very difficult to catch a black cat in a dark room...
                                    Especially when it's not there...!!!!
    1. maogani75
      It's a malfunction that just appeared
      Thank you for your help.. if you can..
