Problem with PowerBook G4, won't turn on
lexa30
Posted messages
3
Status
Member
Anonymous user -
Anonymous user -
Hello,
I have a PowerBook G4, and since last night, it won't turn on anymore. In fact, I didn't turn it off; it was in sleep mode, and when I tried to use it, no keys worked to wake my Mac up, the screen is black.
The sleep light is still on.
Is there a reset button? (other than the forced restart that doesn't work.)
What should I do?
Thank you very much for your help.
Alex
What should I do?
Alex
Configuration: Mac OS X Firefox 2.0.0.12
Precision,
The real trick to reset the PRAM at startup is to simultaneously press and hold the following 4 keys upon startup:
Alt - Apple - P - R
Best regards
Sanspseudo - Francis
iMac G5 2ghz 2GB - OS 10.4.11 -
Hello,
there is a procedure to reset the power management of a PowerBook, see this page
http://docs.info.apple.com/article.html?artnum=14449-en
and more generally, this page
https://support.apple.com/kb/index?page=search&src=support_site.home.search&locale=en_US&q=PowerBook%20G4
Best regards
iMac G5 2ghz 2Go - OS 10.4.11 -
Hello Alex,
disable your battery and try to restart by holding down the Command (Apple) key and R at the same time to clear the memories. Restart again by holding down the Shift key, keep this key pressed until you hear the small sound at startup and until you see the word "safe boot" in the progress bar.
Good luck!
