Platinum take Beogram 1000 not compatible with mains power
Solvedbaladur13 Posted messages 47406 Registration date Status Moderator Last intervention -
I just picked up my grandparents' turntable, a Beogram 1000 model, with a Beomaster amplifier and the associated speakers.
I can plug the amp into the power outlet, but the turntable's power plug won't fit into the wall socket, and I don't understand why???
Help, I’m so eager to listen to all their old vinyl records!
Hello,
Test with a 2P+T and 2P compatible power strip
The first solution, and often the simplest, is to plug your device into a power strip rather than directly into the wall outlet. Some power strips are more tolerant and also accept both two-prong and three-prong plugs.
Hello,
What is wrong?
The spacing of the outlets should not pose a problem, however, the plastic part of the plug may not be able to fit into the current female outlets.
Two solutions:
- Replace the plug with a .
- Slightly file down the plastic part of the plug so that it can be inserted into the wall outlet
Very difficult to catch a black cat in a dark room.
Especially when it isn’t there...-
Hello, thank you for your responses!
Indeed I forced it (I hadn't dared before) and it finally worked :)
On the other hand, only one of the two speakers is functioning; I think it's a connectivity issue related to the amp, and the sound crackles and pops as soon as I touch any button. I will take it to a vintage audio repairer.
Have a good day and thanks again!
Ok...
As for the speaker that isn’t working, try connecting the non-working one in place of the working one and vice versa.
If the problem follows the speaker, the issue is the speaker itself; if, on the other hand, the problem remains on the same output, then the issue is with the amplifier that handles that side.
