FB/Messenger Connection Issue After Meta Outage - Help
Anonymous user -
Hello everyone,
I'm having a problem with my Facebook and Messenger accounts following the Meta outage that occurred earlier today. Because of this outage, I was automatically logged out of both apps on my iPhone, my tablet, and my web browser. When I try to log back in, the system asks me for a code from Microsoft Authenticator, which I no longer have access to since I changed my phone.
To make matters worse, Facebook/Messenger also requires me to approve the login via a previously used device. However, since I've been logged out of all devices, I am unable to do that. I've tried several solutions, but none have worked, and I'm stuck in a loop without receiving any codes.
I'm reaching out to the community to see if anyone else has encountered a similar problem or has suggestions for resolving this issue. I would appreciate any help or advice you could provide, as I need to regain access to these platforms for my work.
Thank you in advance for your assistance.
Still nothing received either, grr. I've tried everything but it seems that the phone number is blocked.
I see I'm not the only one!!! I can't connect to Facebook because I get a message saying a code has been sent to my phone. The last 2 digits of my phone number listed are correct, but I never receive a code! And when I try again, it tells me that the number of code sends is limited and they can't send any more! Have you found a solution? Thank you
Good evening, has anyone found a solution? I'm going crazy with this two-factor authentication. After 48 hours of being locked out, I finally received a code. I managed to log in and immediately wanted to disable two-factor authentication. It's impossible! When I disable it and log back in, I land on a page saying "To log in, please set up two-factor authentication." There's no way to escape it. If I select that I want to log in with an authentication app, nothing happens! I don't know how it works. And if I choose to authenticate with a code via text message: I don't receive any text and I get locked out after a while because it says the number of attempts is limited! I can't get out of this loop, and I've even been logged out of my phone, so I can't log in either to my computer or my phone.
