Realtek RTL8723BE Wireless LAN 802.11 Connection Issue
Solved
JcF -
txiki Posted messages 6514 Registration date   Status Contributor Last intervention   -
Hello,
After trying a bit of all the "software" solutions offered on many forums without any result, I eventually took apart the PC, disconnected the wifi card, cleaned the contact tracks, reassembled everything, and it works perfectly.
In summary, sometimes you also have to look at the "mechanical" side of our dear PCs.
Have a good day.
  1. Panth33ra Posted messages 23152 Registration date   Status Member Last intervention   Ambassadeur 2 359
    Hello,
    I guess you don't have a laptop. The procedure would have been trickier. Thank you for your feedback!
  2. txiki Posted messages 6514 Registration date   Status Contributor Last intervention   609
    Hello everyone!
    Yes, we wouldn't have guessed it was a desktop PC (tower or desktop).
    Anyway, thanks for the feedback.
    Have a great day! (I'm closing the question).
