Sound issue with Redmi Note 10
Solved
Magy -
 abenaissa -
Hello,
I have a problem whenever I try to listen to music, and I can't find a way to resolve it. As soon as I play something, the sound comes out of the phone as well as through my headphones (bluetooth, I’ve tried two different ones, but also wired), and despite scouring the phone settings, I don't know what to do anymore.
The sound therefore comes out simultaneously through the phone's speakers, making the headphones/earbuds completely useless...
Thanks in advance
  1. Andrea
    Hello, have you found a solution because I have the same problem
    thank you in advance
    2
  2. abenaissa Posted messages 9 Status Member 1
    Hello
    I have the same issue. The topic is marked as resolved but no answer is suitable.
    Is it possible to unlock it?
    After research, I found that it's a software problem. I have eliminated many applications without success.
    Whether I connect a BT headset (speaker or headphones) or use the jack, regardless of the application (radio, YouTube, Facebook, TikTok, WhatsApp, podcast, etc.), my Redmi 10pro sends sound to both the speakers and the connected device simultaneously.
    Thank you for any response.
    1. abenaissa Posted messages 9 Status Member 1
      It didn't last long.
      An Android update fixed the issue that disappeared as suddenly as it had come up.
      1. Karen > abenaissa Posted messages 9 Status Member
        Hello,
        I have the same problem for a few days...
        Has it been resolved?
      2. abenaissa > Karen
        Hello,
        It resolved itself without any action on my part. I didn't understand what happened.
        A system update must have taken place.
        Sorry for not being of more help.
  3. Panth33ra Posted messages 23241 Registration date   Status Member Last intervention   Ambassador 2 364
    Hello,
    Do you use an app to listen to your music?
    1. Magy
      Yes Spotify. I also looked at the app settings and I don't see what is causing the bug
      1. Panth33ra Posted messages 23241 Registration date   Status Member Last intervention   2 364 > Magy
         I have a problem as soon as I try to listen to music and I can't find a way to solve it. As soon as I play it, the sound comes out of the phone and also through my headphones (bluetooth, I've tried two different ones, but also wired)
        Let's go back to the headphones. What model? Is your headset properly paired with your smartphone?
        Just for info: I use wireless bluetooth earbuds with an application other than the one mentioned. I import my music files from the PC to the smartphone.
      2. Magy > Panth33ra Posted messages 23241 Registration date   Status Member Last intervention
        I have a JBL, but I tried it with a Bose, and with wired headphones and encountered the same problem every time.
        We also tried my headphones on another phone and there were no issues. So it must be coming from the phone.
