Front panel connector connection issue
Hello, I have a problem with my Acer gx 781 computer. I wanted to change the motherboard to upgrade the processor, but I've encountered an issue with the front panel connector. I can't connect it because the pins are too big compared to the cable.
  • Descending date
  1. Contributor
    Hello,
    Normally it connects... or maybe a misalignment is preventing you from pushing it in... what is it that you have on what you call a "Front Panel"...???
    Are the size... the pitch... the number of contacts correct...?
    You will have a hard time finding this connector (individually) and then re-crimping each wire onto it...
    1. So yes, there is exactly the same number of pins, with a gap in the same place.
    2. This is where I need to connect it, except my cable is different from the one in the diagram.
  2. Contributor
    Hello
    The connector is specific to Acer productions; you need to adapt, cut, and resolder plugs or use an adapter set like https://www.cdiscount.com/informatique/cables-connectiques/1-jeu-carte-mere-interrupteur-alimentation-sw-r/f-1072015-aih9391567768610.html
    Signature
    Euskadi Ta Askatasuna
    1. All I have to do is buy this item and connect it according to the diagram shown above, without soldering or cutting anything? Thank you for your help.
    2. Contributor
      @Simon930
      The diagram you've captured is the standard applied by motherboard manufacturers... Acer rarely adheres to this diagram... you'll have to do a wire-to-wire connection between the connector and the various LEDs and buttons to figure it out; if you're lucky, you won't have to cut anything....
    3. @flo88
      Okay, thank you for your help. I hope I will be lucky ????
