No sound "no audio input device found"
Solved
Hello,
I have been using a new "Acer Nitro 50" PC for 2 months with Windows 10. Since then, the sound has been cutting out at times, and I don’t know what is causing these sound cutouts. The last time, a week ago, Microsoft’s assistant updated the driver for me, and it worked for a few days, but suddenly today there’s no sound again. The time before that, I remember having the choice between Nvidia or Realtek, and I randomly switched from Nvidia to Realtek, and the sound came back for about 2 weeks before disappearing again. The problem today is that the Realtek name has disappeared; it’s nowhere to be found. In the Audio settings, it says there are no audio input devices. We also cannot reinstall the old driver as the box is grayed out.
What can I do? I don’t even know where to look or what to do!
For your information: I have an amplifier connected to my "Acer Nitro," and I have always had amplifiers and never experienced sound problems with that. Everything is properly connected; I have checked it 3 times.
Thank you to anyone who can help me resolve this sound issue.
  1. Moderator
    Hello,
    Windows + R
    Type --> devmgmt.msc and OK.
    Do you have a section --> other devices?
    If yes, what are the problematic devices?
    What do you have in audio, video and game controllers?
    Brand and model number of the PC?
    EX: Nitro AN515-31
    Is Windows up to date?
    Windows key + R
    Type --> winver and OK
    What is the version?
    Example image:
    1. Moderator
      Download and install --> 7Zip 64 bit
      Download this driver --> Realtek
      Right-click on the driver --> Audio_Realtek_6.0.9116.1_W10x64_A.zip
      Select --> 7Zip
      Choose --> extract to "Audio_Realtek_6.0.9116.1_W10x64_A\"
      Go to Device Manager
      Right-click on the High Definition Device
      Update driver
      Browse my computer for drivers
      Select from a list of drivers...
      Have Disk
      Browse
      Go to the unzipped driver folder --> Audio_Realtek_6.0.9116.1_W10x64_A
      Folder --> Audio_Realtek_6.0.9116.1_W10x64
      Folder --> Win64
      Select the file --> HDXACERAIO.inf and OK.
      Restart.
      1. The sound is working now:
        Thank you kaneagle for your helpful assistance.
        1. While reading some tips here and there on this forum about reinstalling sound, I downloaded the Realtek driver (executable). When I tried to install it on my PC, it said "installation failed" without any further information.
          It's getting complicated.
          Can someone help me?
          Thank you.
          1. Hello kaneagle,
            Thank you for helping me, I know you are a pro in the field.
            Under audio, video, and game controllers I have 3 lines:
            Nvidia High Definition Audio
            Nvidia Virtual Audio Device (Wave Executable) (WDM)
            no "other devices" section
            Model Nitro50 - dts x
            Windows version 21H2 build..............19044-1766
            1. HDAUDIO\FUNC_01&VEN_10DE&DEV_009F&SUBSYS_174BA630&REV_1001
              the first line is highlighted.
              1. Moderator
                This no. corresponds to --> Nividia High Definition Audio
                It's the same no. for this one --> High Definition Device ??
                Human beings are at their best when things are at their worst
                1. HDAUDIO\FUNC_01&VEN_10EC&DEV_0897&SUBSYS_1025152D&REV_1004
                  1. It works!
                    1. Moderator
                      You're welcome.
                      Have a nice day.
