Red light stays on JBL Clip 3 and it does not work
Solved
Cici
Michette -
Michette -
Hello,
After charging my JBL Clip 3 speaker (with its original charger), I disconnected it as usual and the red light stayed on. Since then, nothing works; I can't turn it off/on, no sound comes out, and I can't do anything. I've tried to reset it, but nothing works and the red light is still on. When I try to connect via Bluetooth, it doesn't work either.
Can you please help me?
If it can help people who are experiencing the same thing, I just found the solution. After trying everything, I came across a YouTube video; you simply need to press and hold the power button for 20 seconds, and the light will turn on. After that, you can turn it back on as usual, and it will work properly again.
