Connecting an amplifier to an audio tuner...
Solved
djoulk -
 djoulk -
Hello
I would like to purchase an amplifier for my audio FM tuner.
How can I tell and identify if the installation is possible at the back of the tuner, please?
Thank you in advance for your answers.
Best regards.
  1. baladur13 Posted messages 47399 Registration date   Status Moderator Last intervention   14 411
    The tuner has an optical audio output
    The amplifier has 2 optical inputs
    An optical cable between the two should solve the problem
    1. djoulk
      Great!..... A big thank you to you, Baladur13, and have a good afternoon.
      Best regards.
  2. djoulk
    I only have a tuner with two speakers and I would like to connect a small amplifier to it!
      But you already have a MARANTZ PM-6006 DAC
      what would a "small amp" bring that is more?
    2. djoulk
      No baladur13 ... I think I didn't express myself clearly at first:
      I have a Marantz FM tuner and two 100-watt Pioneer speakers (non-amplified). And I would like to add an amplifier to it!
    3. baladur13 Posted messages 47399 Registration date   Status Moderator Last intervention   14 411
      It wasn't you who wrote in message 2
    4. djoulk
      No, there is a mistake!
    5. baladur13 Posted messages 47399 Registration date   Status Moderator Last intervention   14 411 > djoulk
      You’re not lacking in arrogance… same username, same IP address, and it’s not you.
      In any case… if you’re looking for an amp, you need to find an amp that accepts the impedance (4, 8 Ohms or others) listed on the back of your Pioneer speakers.
    OK...
    The technical specifications of the Marantz PM 6006 amplifier state that the amplifier is compatible with 4 or 8 Ohm speakers
    so it's up to you to see if your speakers are 4 or 8 Ohms
    It's very difficult to catch a black cat in a dark room.
    Especially when it isn’t there...
    1. djoulk
      Thank you very much for your response.
      Best regards.
  4. baladur13 Posted messages 47399 Registration date   Status Moderator Last intervention   14 411
    Hello,
    What are the references (Brand and model) of this audio FM tuner?
     Very difficult to catch a black cat in a dark room.
                                  Especially when it’s not there...
    1. djoulk
      Model of the amplifier: MARANTZ PM-6006 DAC
      Model of the tuner: MARANTZ CR 401
  5. djoulk
    Hello
    Could you please advise me on the purchase of a small amplifier to optimize my little sound system?
    Thank you in advance.
    Best regards.
      Optimize my small channel?
      What do you criticize about your amplifier? What more do you want to do?
