Bonton power PS4 doesn't work anymore.
Solved
UzumakiNaruto38
Posted messages
13
Status
Member
Anderz -
Anderz -
1 answer
Hello UzumakiNaruto38,
the PS4 is a fragile console, so even dropping it from 10 cm can damage the system.
You were lucky that the hard drive is intact because it could have had a crack on it. I think the power button broke, or at least the mechanism of the button.
With that, have a good day.-
I don't think so, however you could try to contact them.
Otherwise, if you have a warranty, you can go to the store to exchange your console.
If you know how to tinker, you can also fix it by watching tutorials online, but I know that it requires special tools and quite a bit of skill, if that can help you.
