Problem with Revo Uninstaller Pro
Solved
Anonymous user
MPMP10 Posted messages 47626 Registration date Status Member Last intervention -
Hello,
I installed the application "revo uninstaller pro" to uninstall some programs, but after I tried to uninstall it within the software itself, I didn’t go to Programs and Features, and all... but I found that the icon stayed. I deleted it normally and the problem is when I went to Programs and Features I found at the bottom a folder named after this software, but when I click to enter it says (no program is associated with this file, install one or create an association in the File Manager). And when I right-click it only gives "Create a shortcut on the desktop" anyway, even with CCleaner it does nothing. I tried everything but nothing works. Please I need your help, I want to know what the problem is and how to uninstall this folder? Thanks in advance.
Hi,
Reinstall Revo and this time, uninstall it the proper way, via the Control Panel.
Otherwise, it’s like asking it to cut the branch it’s sitting on... -
Hello ,
https://support.microsoft.com/fr-fr/help/247501/how-to-manually-remove-programs-from-the-add-remove-programs-list
Merry Christmas and happy holidays.
The enemy is stupid: he thinks we are the enemy when it is he who is the enemy!
Pierre Desproges
