RCA CABLE GREEN RED BLUE to WHITE RED YELLOW TNT DECODER
PIERRE.M35 Posted messages 2 Registration date   Status Member Last intervention   -
Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   -
Bonjour. I need to connect my RV satellite TV to FRANSAT using the appropriate decoder. The outputs of the decoder are WHITE, RED, YELLOW. The cable is HDMI (for the TV side) and BLUE RED GREEN RCA for the decoder side. Please match which color with which other? Thank you.
  1. Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   12 202
    No, you didn't understand, read me carefully and are you sure that your decoder does not have an HDMI output? What is its complete reference?
    Reminder:
    TV Inputs:
    Video: Blue, green, and red = component inputs (three cables for video), with green also accepting composite (one cable)
    AND audio inputs red and white
    In any case, I'm sure your decoder has an HDMI output that will allow you to receive in HD because via RCA = SD
    If it's your cable that has these three colors, the green as yellow output from the decoder to the green input of the TV, the blue and red to the red and white outputs of the decoder to the red and white audio inputs of the TV, but again you will only get SD
    I call a spade a spade *
    *in French in the text
    5
