Media Player Classic sound volume issue
Marc -
Pocampe33 Posted messages 63 Status Member -
Hello
I use Media Player Classic to play my video clips recorded on my PC, but the problem is that there is no clip that plays at the same volume level... I spend my time increasing or decreasing the volume... Can someone please let me know if there is a function in Media Player Classic where my volume would all output at the same sound level?
Thanks in advance!!!!
1 answer
  1. Pocampe33 Posted messages 63 Status Member 15
    Good evening,
    To do this, you need to:
    - go to the menu View > Options
    - in Internal Filters, select Audio Switcher
    - on the right side (see below), check the Normalize box
    - to boost the volume, also check the Regain volume box and adjust the slider next to "Boost"
    - apply then Ok
    - close the software and test
    Have a nice evening
    Pocampe33
