How to give a title to each slide in PowerPoint?
chtantoine Posted messages 71 Status Membre -
Raymond PENTIER Posted messages 58549 Registration date   Status Contributeur Last intervention   -
Hello,
I don't know how to rename a slide, do you have a solution? I need to put videos on each slide, but I need to be able to recognize the videos.
So I would like to name the slides (instead of slide number 1..., I would like to use the name of each video...)
Thank you for your help
Configuration: Windows / Chrome 55.0.2883.87
m@rina Posted messages 27266 Registration date   Status Modérateur Last intervention   11 545
Hello,
Your request is not very clear. What do you mean by "Renaming a slide"?
Each slide has a title (unless stated otherwise), and it is this title that will appear in the Hyperlink, Custom Slideshow menus, etc.
If the goal is to give a name for use in a macro, it needs to be named by macro.
m@rina
Beware of the herbal tea: it’s a dangerous poison...
tettix Posted messages 4 Status Membre
Hello,
what does "macro use" mean?
