[Problem] tous les réglages ont été réinitialisés aux valeurs par défaut
Solved
Baroud -
amomo642 Posted messages 384 Status Member -
The previous overclock settings have failed, system has been restored to its default settings
Press f1 to run setup
Press f2 to load default values and run setup.
Hello,
I get this message when I want to turn on my PC.
So my PC crashed while playing CS:GO, I could still navigate with the keyboard on the computer but the mouse was freezing on certain windows, anyway, I turned off the computer. I opened it to clean out some dust, especially the GPU, which I unplugged and then plugged back in. I turn it on again but it turns off almost right after starting, as if the RAM is not seated properly... Well, I try once or twice more and sometimes it turns on and I get to this screen. However, I've never overclocked, and neither f1 nor f2 do anything :(
Thank you very much for your help.
Configuration: Android / Chrome 55.0.2883.91
  1. amomo642 Posted messages 384 Status Member 51
    Hello
    Since you've dismantled your PC, re-dismantle it and remove the flat BIOS battery from the motherboard for 2-3 minutes.
    Your issue should be resolved.
    4
