How to remove this "link" f.ENGINE
lilaeden Posted messages 5 Status Member -
Djo La Force Posted messages 22035 Status Contributor -
Hello,
I'm reaching out to you because I can't find a solution on the forums. Indeed, for the past few days, there's been this rectangle showing up on my screen and I can't use the mouse to remove it. This rectangle appears every 2 seconds. Thank you in advance.
  1. Djo La Force Posted messages 22035 Status Contributor 1 839
    Hi
    It's the touch screen... This is the one that gets disabled, but if that's happening, it's either due to something on the touch surface (a case I've seen more than once after a cleaning wipe), or the screen itself has a defect.
    The Force is like computers, its actions are unpredictable.
    2
    1. lilaeden Posted messages 5 Status Member
      Good evening,
      Thank you for your reply. It's not a tablet, it's a "desktop PC". I have indeed noticed that the screen seems to be split in two (one side darker than the other) and since then, this rectangle keeps appearing. What do you recommend, just in case? Thank you in advance.
    2. Djo La Force Posted messages 22035 Status Contributor 1 839
      Well yes, I know it's a desktop PC, with an LG screen... But the adjustment buttons at the bottom of the screen are indeed touch-sensitive... You didn't clean it just before it started doing that, did you?
    3. lilaeden Posted messages 5 Status Member
      Good evening, no the buttons are not touch-sensitive, they are on the right side (off-screen). I forgot about the cleaning!!
    4. Djo La Force Posted messages 22035 Status Contributor 1 839
      A key must unlock it, the one marked f-engine.
