How to add fonts on Android to work in Word
Lilinnette -
Cpassimple Posted messages 3987 Status Member -
Hello,
I have a Samsung Tab A (Android).
I would like to use it for my work, so I downloaded Word for word processing, but some fonts I use on my PC are not installed on my tablet, which is blocking certain folders.
I installed the iFont app on my tablet to save my new font. However, this font still does not appear in Word. I can only use it as the default writing font on the tablet's home screen.
Can you help me install this font so that the Word software on my tablet recognizes it and allows me to use it??
Thank you in advance.
Have a great day
Configuration: Windows / Chrome 49.0.2623.112
1 answer
  1. Cpassimple Posted messages 3987 Status Member 923
    Hello
    First, you need to check the Settings in the Security tab: Allow unknown sources
    You need to download: Es Explorer (free from the Android store)
    From there, go to /sdcard/ifont/custom
    You can also do this by connecting your phone to a PC, but you need to enable USB Debugging on the phone
    To do this, go to the settings and select: About phone or tablet, click on Build number until: Congratulations, you are a developer (or something like that appears)
    Then go back, Developer options, etc....
    From there, you can add your .tft files
    Don't overdo it, on Android it's not great to have too many fonts
    i7 4790k 4.9GHz / 16GB 2133MHz / GTX 980 ti
    16
    1. Lilinnette
      Hello Cpassimple,
      I would like to clarify that I am not on a PC, but rather on a Samsung Tab A tablet and therefore under Android.
      (My fonts are already installed on my PC but I would like them on my tablet so that I can work on the documents on both PC and tablet while keeping the layout and the fonts used ...)
      1. Cpassimple Posted messages 3987 Status Member 923 > Lilinnette
        I have corrected my post as many times as I have read yours; my first reading was not the correct one, but the mistake has been fixed.
      2. Cpassimple Posted messages 3987 Status Member 923 > Cpassimple Posted messages 3987 Status Member
        Es Explorer is here.
        -1
    2. Lilinnette
      Hello,
      thank you for your reply.
      I have downloaded Es Explorer on my tablet and added my font in ifont/custom, but it still doesn’t appear in Word...
      Can you explain to me why and how to do it?
      Thank you
        Are the fonts in .tft format?
        Otherwise, I'm sorry, I deleted Office from my Android devices (I prefer to write on Windows and the app is too power-hungry, even with the latest generation of devices).
