Comment connecter la console WII à la TV SAMSUNG LED UE40H5003
Solved
Jeanmimi
pipod Posted messages 3 Status Member -
Hello,
I bought a new SAMSUNG TV that does not have RCA inputs (yellow, white, red). It only has 2 HDMI, 1 USB, 1 optical, and one SCART. Therefore, I cannot connect my WII game console purchased in 2009.
I bought an RCA/HDMI converter, but it doesn't work!! NOTHING AT ALL!!
Is there a solution or do I have to give up playing on the WII???
Configuration: Windows / Firefox 42.0
Thank you for the quick response. I'm going to buy the said socket and I'll keep you updated.
- Hello Andy,
I just picked up the adapter you recommended and have installed it.
After checking the connections, the selected source (SCART socket)
the position of the switch on 'in', that the console was indeed on and that a CD was inserted, NOTHING AT ALL: no signal, check...........
Anyway, it doesn't work!!! I think it's dead and there must be a signal incompatibility between the WII and the TV.
Thanks anyway for trying to help me.
Those bastards of manufacturers do what they want, you have to say that the SCART is no longer mandatory, so it's very possible that this SCART is on the chassis of your TV but not wired. I found you another solution:
https://www.amazon.fr/s/?ie=UTF8&keywords=convertisseur+video+hdmi&tag=googhydr0a8-21&index=aps&hvadid=57837674788&hvpos=1t1&hvexid=&hvnetw=g&hvrand=3182776011067353575&hvpone=&hvptwo=&hvqmt=e&hvdev=c&ref=pd_sl_6yju8a1enf_e
