HDMI Port Issue Continental Edison LED
athena2612 Posted messages 4 Status Member -
Hello,
I have a problem with my Continental Edison TV model ce62lcd32hd3.
The HDMI port is no longer working... When I connect a device (PS3 or PS4 console), I see the image appear for a few seconds and then it disappears.
We took it to the repair shop where they reset the TV, and they said it should work, but nothing has changed...
Thank you for your help!
  1. athena2612 Posted messages 4 Status Member 15
    When we went to the repair shop, he managed to access hidden menus, but we can't seem to find them again...
    Do you know if there’s a specific manipulation to do?
    9
  2. athena2612 Posted messages 4 Status Member 15
    It does the same thing regardless of the cable and the outlet; we tried with other cables and devices, it really only comes from the TV.
    5
  3. Froulik Posted messages 4292 Status Member 955
    OK.
    The problem is that if it's a TV issue, I really don't see what CCM can do...
    I would say "head to customer service". other than that?
    Oh yes, maybe a firmware update. It's worth a try.
    Have a good evening anyway :o/
    Those who know nothing always know as much as those who don't know any more than they do. (Pierre Dac)
    2
  4. athena2612 Posted messages 4 Status Member 15
    I think I'm going to take it to the repair shop
    thanks anyway, have a good evening
  5. Froulik Posted messages 4292 Status Member 955
    and the cable? Has it been checked?
    and the connection (socket)?
    Those who know nothing know just as much as those who know no more than they do. (Pierre Dac)
