Samsung UE40ES6300 TV Stand Problem (Cross Stand)
Solved
BoBby_SpOKe
Posted messages
63
Status
Member
BoBby_SpOKe Posted messages 63 Status Member -
Hello,
I just received my Samsung TV this morning, and I have a small problem: there are no screws to attach the stand to the TV. Also, the stand is in two parts, and there are no screws either, just 4 holes without any visible threads. I couldn't find any information online regarding this issue. Does anyone know what type of screws are needed (length and diameter) and how to attach these two parts of the stand together?
Thanks in advance!
Configuration: Windows 7 / Firefox 22.0
Thanks in advance!
Hello,
entering this Samsung reference into Google returns:
SCREW-MACHINE;CH,+,M2,L4,NI PLT,SWRCH18A
It's really tiny like a screw ...
A diameter of M2 and a length of L4 (4 mm)
We should find equivalents for less than one euro in a hardware store.
In the screws or hardware section, with this standardized reference (the one from Google, not Samsung's) they will give you the correct head profile / these are not wood screws ;-) but assembly screws.
Don't worry, they should understand the line (normally)
SWRCH18A is the quality of the steel ... NI PLT, CH and + I don't know what that corresponds to ...
When you manage projects of all kinds, you also have to know about mechanics and electricity ... which requires knowing some standards ... ;-)
In the link I sent in the first response, it was mentioned that the original bag of screws is "hidden" in the polystyrene ... Were they really not there?
quick, rummage through the trash :p
Thank you very much! No, I looked at the styrofoam from all angles, nothing at all! And you have to be crazy to throw away the TV box on the first day without knowing if there will be a return to make^^. I went to the hardware store but I couldn't find the right screws lol.
But can you give me the screws that also allow me to assemble the two parts of the stand together?
Or are they the same, but I doubt it, and then I would need to take 8 screws! -
