Problem with a Starcom TNT tuner decoder
Solved
gbin -
Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   -
Hello,
I have a Starcom TNT tuner that stubbornly sends a window to the TV screen saying "tuner power" at intervals of a few seconds. The image is otherwise good. What should I do? Does anyone have an idea to eliminate this nuisance??
Thanks.
Configuration: iPad / Safari 6533.18.5
1 answer
  1. Anonymous user
    hello
    go to the settings menu
    disable or enable the 'antenna power + 5 V' option depending on the case
    11
    1. G.D
      Thank you for the advice, I had the same problem and I solved it thanks to your response.
      Gilbert
    2. Martin
      I don’t have that option when I’m in the settings menu
    3. dimdimjule Posted messages 1 Registration date   Status Member Last intervention
      problem of the Starcom 8817 decoder: it shows "alimentación tuner" on the TV, what to do.
    4. Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   12 207
      See above for cricri's answer.....
