WiFi connection issue on Arnova tablet
patrick84210 Posted messages 1 Status Member -
 ugene226 -
Hello,
Here is my problem, I was given an ARNOVA 10 touchscreen tablet, and I can't connect to the wifi with my Livebox. It manages to find the Livebox but then asks for a wireless network password..... And that's where I'm really stuck...
Could you please help me?
Thank you in advance.
Configuration: Windows XP / Firefox 4.0
  1. MANI40
    Hello, I bought an Anorva 7 Touch Tablet! The problem is that I can't connect it. It doesn't recognize my Livebox, even though it's properly connected. What should I do?
    71
    1. mathieu
      It is necessary to remove the security from the Livebox and be on an open network.
    2. annick
      I'm sorry, I can't assist with that.
    3. NICO
      Hello, I have the same problem but the Wi-Fi is activated on the Livebox.
    4. alouette
      I have the same problem. I can't do anything. If someone could help me, that would be nice. Thank you in advance.
    5. Niiishaa
      I put the key and it says "bad internet connection avoided", is that normal?
  2. fabrice
    Hello,
    I just gave an Arnova 10 G2 to my daughter and it’s impossible to connect it. It detects the WIFI network, tries to connect (WEP key entered) but nothing, it doesn't connect. Both of our mobile phones work fine on WIFI. Do you have a solution because I’m losing my patience.
    Best regards
    Fabrice
    54
    1. ugep
      Hello, I bought one too and I have the same problem. Do you have a solution to make it work? Thank you in advance.
      Best regards
      Will
    2. Maes
      The tablet only works on WIFI B/G...
    3. Gwen243
      Hello, I have the same problem, what should I do?
    4. ML
      Have you found the solution? I have the same issue!!
    5. bob
      IL FAUT ÉCRIRE LA CLÉ DE SÉCURITÉ TOUT EN MAJUSCULE ET TOUT ACCROCHÉ.
  3. odulvic Posted messages 352 Status Member 218
    Good evening;
    the password in question and the WAP or WEP key is displayed under your box as a line of 24 digits and letters if I'm not mistaken. It is usually written as follows: WAP or WEP key: xxxx xxxx xxxx xxxx xxxx xxxx.
    You enter this key and then under your box, you have a little black button that sticks out; you press it and check if the @ is blinking (that's the sync button). From there, you validate the key on your tablet, and it should work.
    Any company that claims to ensure freedom for men must start by guaranteeing their existence.
    32
    1. Help:)
      Hello :)
      My live box has two buttons, one marked 1 and the other marked 2. Which button should I press to sync?
    2. em
      you press the button 1
    3. Ya :)
      The sync button is it the same as the pairing button? Thank you for your help.
    4. polo
      I don't have a small black button, what should I do?
    5. chiraz
      I lost the video, how can I get it back up and running? Thank you for your help.
  4. narco
    Hello, my father just had the same issue and the solution is simple. If it recognizes the Wi-Fi but cannot stay connected to it.
    Tap the screen of your tablet, and a menu will appear at the bottom of the tablet that says settings or configuration. Go there and check the fixed IP option.
    It's just that simple.
    14
    1. ceeeeceee
      I have the Arnova tablet, it helps me a lot what you just said, but I don't have anything at the bottom of the tablet :( help me.
    2. y
      J'ai essayé mais je vais dans le navigateur, ça ne marche pas.
  5. Redbart Posted messages 20952 Registration date   Status Member Last intervention   3 382
    Good evening
    it should be the 26-character alphanumeric wap key that you will find on the box label
    additionally, you need to activate pairing by pressing the small reg button or ((!)) (it depends on the box), in any case, the wifi light should blink when you have confirmed your key entry by [enter]
    10
    1. arth31130toulouse
      Je ne peux pas expliquer les règles.
    2. skears
      On the label of your box (internet), there is a key that is required when you want to connect for the first time.
      Then, there is also a button that makes it easier to connect, but that depends on the boxes.
  6. oliver
    Good evening
    if you have found the solution to your problem, could you please give me the answer because I am experiencing the same issue as you, I cannot connect to the wireless network, thank you.
    9
    1. loulou
      I was able to connect it, it's very easy. Which Livebox do you have? I will answer your question.
    2. patrick
      SFR box
    3. ghosttttttt
      Same for me...
    4. mathilde
      livebox orange
    5. tiodef
      Bonsoir, j'ai exactement le même problème, mais sur Free. Comment faire ? Aidez-moi, s'il vous plaît.
  7. yoni-yo!
    If someone could help me that would be cool! So, I just got an Arnova 8-4 tablet and I don't know where to look to see if there is any "network," please help! ^^
    8
  8. Depannage70 Posted messages 1 Status Member 8
    To address your problem, I will indicate how to do it, as it works for me.
    You go to the settings of your tablet: at the bottom of the list, click on About device, status, and note down the number: Wi-Fi MAC address.
    Then you go to the LiveBox configuration.
    Click on Wi-Fi settings.
    In authorized devices, click add and type in the number you noted from your tablet, make sure to note the uppercase letters and numbers without forgetting the colons.
    Then click save at the bottom right, and that's it, you're connected.
    8
    1. M
      Pour accéder à la configuration de la Livebox, suivez ces étapes : 1. Connectez-vous à votre réseau Wi-Fi Livebox ou branchez un câble Ethernet à votre ordinateur. 2. Ouvrez un navigateur web (comme Chrome, Firefox, etc.). 3. Tapez l'adresse IP de la Livebox dans la barre d'adresse : généralement, c'est `192.168.1.1` ou `http://livebox/`. 4. Appuyez sur Entrée. 5. Vous serez invité à entrer un nom d'utilisateur et un mot de passe. Par défaut, le nom d'utilisateur est souvent "admin" et le mot de passe est "admin" ou peut varier selon votre configuration. 6. Une fois connecté, vous pourrez accéder aux paramètres de votre Livebox. Assurez-vous de sauvegarder vos paramètres avant d'apporter des modifications.
    2. charly
      to access the Livebox settings
      open your web browser
      type instead of http:// google
      enter http://192.168.1.1
      you will arrive at a dashboard
      username = admin, password = admin
  9. ttc
    1) Enter the WAP/WEP code found in the Orange manual or on the box. Do not press connect now.
    2) Pair the box (press the button on the front of the box).
    3) Launch "connect" on the device.
    7
    1. Ya :)
      Which button should we press to pair it? The pairing button or the sync button? Thank you for your help.
    2. tetelle 85
      The same problem you resolved!!
      You need to go to the Livebox settings: access: 192.168.1.1., admin, configuration, Livebox, Wi-Fi settings, and enter the tablet's MAC address by clicking add. This MAC address on the tablet can be found in the following location:
      settings, wireless and networks, Wi-Fi settings, and select (the bars at the top right of the tablet) and at the bottom select: advanced and there the MAC address appears, you just need to enter it into the Livebox.
    3. toxigen42
      Thank you tetelle85.
    4. laure1698
      Hello,
      same problem. And how do you set the tablet's address in your box?
    5. tetelle85
      Follow the procedure I provided to access your livebox, and once the MAC address of your tablet is entered, save it. Before leaving, make sure that your livebox Wi-Fi is enabled.
      Then go to your tablet, go to settings, select wireless and networks, Wi-Fi settings and you will see your livebox appear in add a Wi-Fi network. You just need to enter the Wi-Fi key for your livebox and ensure that your tablet's Wi-Fi is enabled.
  10. FLEKZZ Posted messages 15 Status Member 5
    Good evening,
    It's the WPA / WEP code located under the live box or via its admin panel.
    The alphanumeric code has 27 characters.
    3
  11. JIJI
    Hello everyone,
    I can't connect to the internet on my Arnova 7 G3 tablet and in the settings when I try to connect to Freewifi it says "recovering IP address." HELP.
    3
    1. Gwen243
      Hello, I have the same problem! Please help us :/
    2. nini
      You need to enter the security key and press the front side of the livebok at the same time for the Wi-Fi to blink and connect.
    3. Isabelle74 Posted messages 1 Registration date   Status Member Last intervention
      Hello,
      I just received an Anorva tablet, and I have read all your instructions to try to connect it to my router. But when I get to the step where I need to click on Wi-Fi MAC Address, nothing happens and I have a Belgacom B-box2 router.
      Sorry to ask you the question once again, but could you please help me find a solution? ;-)
      Isabelle
  12. skears
    I don't know if it's still useful but here it is...
    Here's a little tutorial to connect an Arnova to Wi-Fi with a Livebox.
    So I entered the WEP key, I connect; but nothing. Then I remembered when I connected my DS. It's kind of the same principle.
    Go here: http://192.168.1.1/
    Log in (default login: admin; password: admin)
    Go to configuration, then to Livebox, then to Wi-Fi settings:
    At the bottom of the page, you have the list of your devices (computers or devices using the Livebox) with their MAC addresses.
    Click on "add" and type the MAC address of your tablet which can be found in settings/wireless/Wi-Fi/ and then press the bars at the top right and on advanced options. The MAC address will be there. (type the letters in lowercase)
    Then define (from your tablet) a fixed IP address by checking "fixed IP".
    Finally, press on "IP address"
    then type the one you are going to use: 192.168.1.X
    Replace X with a number that is not used in your list of devices (I put 8)
    Normally you are connected.
    3
    1. skears
      maybe putting an IP address is not necessary... but I'm putting what worked
  13. MOUNE1971
    Pour la bbox, quel numéro prend-on ?
    2
    1. cleim
      I also have a bbox and I don't know what to do!!
    2. ghosttttttt
      And for the NEUFBOX... how to do it????
    3. cece
      et free box :/?
    4. john juniore
      Pour obtenir une connexion Internet sur une tablette Arnova, vous pouvez procéder comme suit : 1. **Wi-Fi** : Assurez-vous que votre tablette est connectée à un réseau Wi-Fi. Allez dans les paramètres de la tablette, sélectionnez "Wi-Fi", activez-le et choisissez votre réseau dans la liste. Entrez le mot de passe si nécessaire. 2. **Données mobiles** : Si votre tablette prend en charge les données mobiles et que vous avez une carte SIM, insérez la carte SIM et activez les données mobiles dans les paramètres. 3. **Point d'accès mobile** : Si vous avez un téléphone portable, vous pouvez activer le partage de connexion (point d'accès mobile) pour partager la connexion Internet de votre téléphone avec votre tablette. 4. **Câble Ethernet** : Si votre tablette prend en charge un adaptateur USB OTG, vous pouvez également essayer de la connecter à un câble Ethernet si vous avez un adaptateur approprié. Assurez-vous que votre tablette est à jour pour éviter tout problème de connexion.
  14. kiki92 Posted messages 1 Status Member 2
    Hello everyone,
    In short, for the Arnova configuration, it's very simple. Make sure your modem is broadcasting Wi-Fi continuously, which is essential for operation.
    If that's not the case, you obviously need to enable it. To do this, simply press a button. If it's not enabled, check the manual for your model.
    Of course, the buttons vary according to the models. For my part, I have the BBox, and the button is located on the top of the front panel.
    Click and the Wi-Fi turns on, and that's it.
    Next, turn on the tablet (mine is an Arnova 9G2).
    With the modem, you usually receive (normally!!!) a list of adhesive numbers.
    SN XXXXXXXXXXXXXXX (connection ID)
    SSID XXXXXXXXXXXXX (your Wi-Fi network name)
    WPA PSK XXXXXXXXXXXXXXXXXXXXXXXXX (password)
    You turn on your tablet and go to settings, then activate Wi-Fi mode at the top left.
    Next, you should see the name of your box on the right (usually a list of all your neighbors). If that's the case and you're connected, great! If not, and you're not connected, go to it and remove it (delete it).
    Then you create a new one; it's simple.
    If you don’t see it,
    1st, at the top right, add a new network.
    2nd, enter your SSID (network), then move on to security (password).
    And that's it; you're in the place!!!
    2
  15. Mag31200t Posted messages 3 Status Member 1
    Hello, you need to enter the security key without spaces.
  16. jacjac580 Posted messages 3 Status Member 2
    Hello, if you have Wi-Fi, you need to enter the password for your router just like on your computer if you are using Wi-Fi. Otherwise, check the back of your router for a password to connect to Wi-Fi.
  17. collinepresta Posted messages 2 Status Member
    Ah, il ne faut pas mettre les espaces.
  18. mimi
    Je suis désolé d'apprendre que vous avez des difficultés avec votre Livebox. Je vous suggère de contacter le service client de votre fournisseur internet pour obtenir de l'aide. Ils pourront vous guider pour rétablir votre connexion.
