TNT issue : LNB cable overload
Solved
cidark -
 Okboumer -
Hello, everything is in the title: my TNT SAT decoder has been malfunctioning since yesterday, and today I wake up to find it displaying "LNB cable overload, please turn off the decoder and check the cable."
I really don't understand where this could be coming from, especially since it's been working fine for 3 months. Does anyone have any idea?
  1. padou
    you go to the decoder menu, then to system settings, after that to antenna power and you set it to off, there you go, and it works
    61
    1. kikoo
      Hello padouer, you're ugly.
      1. kikoolol > kikoo
        tu es toi kikoo
    2. DD
      LNB overload concerns satellite TV: so check the cable or the LNB
      Antenna overload concerns antenna TV "classic": so check the cable (possible amplifier) or the decoder programming
      In both cases, the decoder may also be "acting up"
