Probleme message you have a security problem
Bonjour,j'ai le message "you have a security problem!" qui s'affiche en permanence avec ensuite une fenetre qui s'ouvre
j'ai pu lire dans les autres sujets qui traitent du meme probleme que vous voulez une copie du rapport hijackthis
donc voici le mien:
Scan saved at 19:24:45, on 06/11/2008
Platform: Windows XP SP1 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Roxio\Easy CD Creator 6\AudioCentral\RxMon.exe
C:\Program Files\CyberLink\PowerCinema\PCMService.exe
C:\PROGRA~1\WANADOO\TaskbarIcon.exe
C:\Program Files\Java\jre6\bin\jusched.exe
C:\Program Files\ScanSoft\OmniPageSE2.0\OpwareSE2.exe
C:\WINDOWS\VM_STI.EXE
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\WINDOWS\RTHDCPL.EXE
C:\Program Files\Fichiers communs\InstallShield\UpdateService\issch.exe
C:\WINDOWS\System32\ctfmon.exe
C:\Program Files\Messenger\MSMSGS.EXE
C:\DOCUME~1\CELINE\LOCALS~1\Temp\a.exe
C:\Program Files\AskBarDis\bar\bin\AskService.exe
C:\Program Files\Microsoft Office\OFFICE11\WINWORD.EXE
C:\Program Files\Java\jre6\bin\jqs.exe
C:\DOCUME~1\CELINE\LOCALS~1\Temp\~tmpd.exe
C:\WINDOWS\System32\MsPMSPSv.exe
C:\Program Files\Roxio\Easy CD Creator 6\AudioCentral\Playlist.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\WINDOWS\System32\tPlu1s5A.exe
C:\WINDOWS\System32\wuauclt.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
C:\Program Files\Internet Explorer\iexplore.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Wanadoo
R3 - URLSearchHook: Search Class - {08C06D61-F1F3-4799-86F8-BE1A89362C85} - C:\PROGRA~1\WANADOO\SEARCH~1.DLL
R3 - URLSearchHook: DefaultSearchHook Class - {C94E154B-1459-4A47-966B-4B843BEFC7DB} - C:\Program Files\AskSearch\bin\DefaultSearch.dll
O2 - BHO: AskBar BHO - {201f27d4-3704-41d6-89c1-aa35e39143ed} - C:\Program Files\AskBarDis\bar\bin\askBar.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O3 - Toolbar: Ask Toolbar - {3041d03e-fd4b-44e0-b742-2d9b88305f98} - C:\Program Files\AskBarDis\bar\bin\askBar.dll
O4 - HKLM\..\Run: [Windows Update] C:\WINDOWS\System32\lvdlsa.exe
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\System32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [RoxioEngineUtility] "C:\Program Files\Fichiers communs\Roxio Shared\System\EngUtil.exe"
O4 - HKLM\..\Run: [RoxioAudioCentral] "C:\Program Files\Roxio\Easy CD Creator 6\AudioCentral\RxMon.exe"
O4 - HKLM\..\Run: [PCMService] "C:\Program Files\CyberLink\PowerCinema\PCMService.exe"
O4 - HKLM\..\Run: [WOOWATCH] C:\PROGRA~1\WANADOO\Watch.exe
O4 - HKLM\..\Run: [WOOTASKBARICON] C:\PROGRA~1\WANADOO\TaskbarIcon.exe
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre6\bin\jusched.exe"
O4 - HKLM\..\Run: [OpwareSE2] "C:\Program Files\ScanSoft\OmniPageSE2.0\OpwareSE2.exe"
O4 - HKLM\..\Run: [OPSE reminder] "C:\Program Files\ScanSoft\OmniPageSE2.0\EregFre\Ereg.exe" -r "C:\Program Files\ScanSoft\OmniPageSE2.0\EregFre\ereg.ini"
O4 - HKLM\..\Run: [BigDogPath] C:\WINDOWS\VM_STI.EXE PLEOMAX Web Camera
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [SkyTel] SkyTel.EXE
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE
O4 - HKLM\..\Run: [ISUSPM Startup] C:\PROGRA~1\FICHIE~1\INSTAL~1\UPDATE~1\isuspm.exe -startup
O4 - HKLM\..\Run: [ISUSScheduler] "C:\Program Files\Fichiers communs\InstallShield\UpdateService\issch.exe" -start
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\ctfmon.exe
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\MSMSGS.EXE" /background
O4 - HKCU\..\Run: [MSFox] C:\DOCUME~1\CELINE\LOCALS~1\Temp\a.exe
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'Default user')
O8 - Extra context menu item: E&xporter vers Microsoft Excel - res://C:\PROGRA~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: Recherche - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Related - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O9 - Extra 'Tools' menuitem: Show &Related Links - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\MSMSGS.EXE
O9 - Extra 'Tools' menuitem: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\MSMSGS.EXE
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://www.update.microsoft.com/...
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Runtime Environment 1.6.0) - https://sdlc-esd.oracle.com/ESD5/JSCDL/jre/6u10-b92-b/jinstall-6u10-windows-i586-jc.cab?GroupName=JSC&FilePath=/ESD5/JSCDL/jre/6u10-b92-b/jinstall-6u10-windows-i586-jc.cab&BHost=javadl.sun.com&File=jinstall-6u10-windows-i586-jc.cab&AuthParam=1580987764_a5235be86e79daca0cfb05ddc36bfbcd&ext=.cab
O16 - DPF: {DFB5BCF1-06AE-4ABB-BFA8-1E228F41C50A} (CamfrogWEB Advanced Unicode Control) - https://www.bobtv.fr/download/cfweb_www.bobtv.fr-download_instmodule.exe
O23 - Service: ASKService - Unknown owner - C:\Program Files\AskBarDis\bar\bin\AskService.exe
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe
End of file - 6894 bytes
personnellement je n'y comprend rien mais si vous pouvez m'aider cela me rendra un grand service
j'attend votre aide avec impatience
Internet Explorer 6.0
  1. Contributeur sécurité
    bonsoir ,
    Télécharge SDFix (créé par AndyManchesta) et sauvegarde le sur ton Bureau.
    http://downloads.andymanchesta.com/RemovalTools/SDFix.exe
    Double clique sur SDFix.exe et choisis Install pour l'extraire dans un dossier dédié sur le Bureau. Redémarre ton ordinateur en mode sans échec en suivant la procédure que voici :
    • Redémarre ton ordinateur
    • Après avoir entendu l'ordinateur biper lors du démarrage, mais avant que l'icône Windows apparaisse, tapote la touche F8 (une pression par seconde).
    • A la place du chargement normal de Windows, un menu avec différentes options devrait apparaître.
    • Choisis la première option, pour exécuter Windows en mode sans échec, puis appuie sur "Entrée".
    • Choisis ton compte.
    Déroule la liste des instructions ci-dessous :
    • Ouvre le dossier SDFix qui vient d'être créé dans le répertoire C:\ et double clique sur RunThis.bat pour lancer le scrïpt.
    • Appuie sur Y pour commencer le processus de nettoyage.
    • Il va supprimer les services et les entrées du Registre de certains trojans trouvés puis te demandera d'appuyer sur une touche pour redémarrer.
    • Appuie sur une touche pour redémarrer le PC.
    • Ton système sera plus long pour redémarrer qu'à l'accoutumée car l'outil va continuer à s'exécuter et supprimer des fichiers.
    • Après le chargement du Bureau, l'outil terminera son travail et affichera Finished.
    • Appuie sur une touche pour finir l'exécution du scrïpt et charger les icônes de ton Bureau.
    • Les icônes du Bureau affichées, le rapport SDFix s'ouvrira à l'écran et s'enregistrera aussi dans le dossier SDFix sous le nom Report.txt.
    • Enfin, copie/colle le contenu du fichier Report.txt dans ta prochaine réponse sur le forum
    Ensuite :
    Vide tes fichiers temporaires avec ceci:
    ->Clean Up 40:
    http://pageperso.aol.fr/balltrap34/CleanUp40.exe
    ->aide en image:(merci a Balltrap34)
    http://pageperso.aol.fr/balltrap34/democleanup.htm
    click sur option et décoche la case devant : delete prefect files
    vide le manuellement :
    :: Le contenu du dossier prefetch ::
    * C:\WINDOWS\Prefetch <= sauf le fichier layout.ini
    * Ne pas oublier de vider la corbeille !
