Gravure échoue tout le temps
Impossible de graver ma musique, que ça soit sur nero 7, qui plante toujours aux alentours de 70%, ou même par windows, qui ne finalise pas bien le cd.
La log de mon dernier plantage nero:
Merci d'avance, je m'arrache les cheveux, et impossible d'écouter la musique que j'aime...
NT-SPTI used
Nero Version: 7.9.6.0
Internal Version: 7, 9, 6, 0
Recorder: <PIONEER DVD-RW DVR-K17RS>Version: 1.00 - HA 1 TA 0 - 7.9.6.0
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <PIONEER DVD-RW DVR-K17RS>Version: 1.00 - HA 1 TA 0 - 7.9.6.0
=== Scsi-Device-Map ===
DiskPeripheral : ST980815A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-K17RS atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-K17RS D: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1022MB (1046572kB)
Free physical memory: 567MB (581532kB)
Memory in use : 44 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
7.7.2008
Audio CD
14:15:36 #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
14:15:36 #2 CDADOC -1 File Cdadoc.cpp, Line 1588
Audio item log info:
Audio document burn settings:
Burn mode: TAO,
CD Text: Off,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 04:10.34, Pause frames: 150, Filters: 0, Name: 'cocorosie - la maison de mon reve - 01 - terrible angels.mp3'.
Track 02: Length: 03:59.54, Pause frames: 150, Filters: 0, Name: 'cocorosie - la maison de mon reve - 02 - by your side.mp3'.
Track 03: Length: 04:23.13, Pause frames: 150, Filters: 0, Name: 'cocorosie - la maison de mon reve - 04 - good friday.mp3'.
Track 04: Length: 01:19.68, Pause frames: 150, Filters: 0, Name: 'cocorosie - la maison de mon reve - 05 - not for sale.mp3'.
Track 05: Length: 03:36.69, Pause frames: 150, Filters: 0, Name: 'cocorosie - la maison de mon reve - 06 - tahiti rain song.mp3'.
Track 06: Length: 02:56.20, Pause frames: 150, Filters: 0, Name: 'cocorosie - la maison de mon reve - 07 - candy land.mp3'.
Track 07: Length: 01:24.63, Pause frames: 150, Filters: 0, Name: 'cocorosie - la maison de mon reve - 09 - west side.mp3'.
Track 08: Length: 03:49.26, Pause frames: 150, Filters: 0, Name: 'Cocorosie - La Maison De Mon Reve - 10 - Madonna.mp3'.
Track 09: Length: 04:55.68, Pause frames: 150, Filters: 0, Name: 'cocorosie - la maison de mon reve - 11 - hatian love songs.mp3'.
Track 10: Length: 04:04.12, Pause frames: 150, Filters: 0, Name: 'cocorosie - la maison de mon reve - 12 - lyla.mp3'.
Track 11: Length: 04:14.05, Pause frames: 150, Filters: 0, Name: 'Cocorosie - Noah's Ark - 04 - Bear Hides And Buffalo.mp3'.
Track 12: Length: 00:48.67, Pause frames: 150, Filters: 0, Name: 'Cocorosie - The Adventures Of Ghosthorse And Stillborn - 11 - Girl And The Geese.mp3'.
Track 13: Length: 04:47.27, Pause frames: 150, Filters: 0, Name: '030 - 01 - samba da Benção - Bebel Gilberto.mp3'.
Track 14: Length: 04:37.25, Pause frames: 150, Filters: 0, Name: '031 - 02 - Track 2 - Bebel Gilberto.mp3'.
Track 15: Length: 03:01.51, Pause frames: 150, Filters: 0, Name: '032 - 03 - Track 3 - Bebel Gilberto.mp3'.
Track 16: Length: 03:10.59, Pause frames: 150, Filters: 0, Name: '033 - 04 - Track 4 - Bebel Gilberto.mp3'.
Track 17: Length: 04:17.07, Pause frames: 150, Filters: 0, Name: '034 - 05 - Track 5 - Bebel Gilberto.mp3'.
Track 18: Length: 04:04.63, Pause frames: 150, Filters: 0, Name: '035 - 06 - Track 6 - Bebel Gilberto.mp3'.
Track 19: Length: 03:32.39, Pause frames: 150, Filters: 0, Name: '036 - 07 - Track 7 - Bebel Gilberto.mp3'.
Track 20: Length: 02:24.53, Pause frames: 150, Filters: 0, Name: '037 - 08 - Track 8 - Bebel Gilberto.mp3'.
Track 21: Length: 03:26.56, Pause frames: 150, Filters: 0, Name: '038 - 09 - Track 9 - Bebel Gilberto.mp3'.
Track 22: Length: 04:14.52, Pause frames: 150, Filters: 0, Name: '039 - 11 - close your eyes - Bebel Gilberto.mp3'.
Total size: 78:05.31
14:15:36 #3 Text 0 File Burncd.cpp, Line 3196
Buffer underrun protection activated
14:15:37 #4 Text 0 File AudioCompilationImpl.cpp, Line 838
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
14:15:37 #5 Text 0 File Burncd.cpp, Line 3508
Turn on Track-At-Once, using CD-R/RW media
14:15:38 #6 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 351255 ( 78:05.30)
14:15:38 #7 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
14:15:38 #8 Text 0 File DlgWaitCD.cpp, Line 2964
Recorder: PIONEER DVD-RW DVR-K17RS;
CDR code: 00 97 24 16; OSJ entry from: SONY Corporation
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 18 10 (LI 97:24.16), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid)
14:15:38 #9 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
14:15:38 #10 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (cocorosie - la maison de mon reve - 01 - terrible angels.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 18784 (18784) = #18784/4:10.34
relocatable, disc pos for caching/writing not required/not required
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18782 blocks [D: PIONEER DVD-RW DVR-K17RS]
1: TRM_AUDIO_NOPRE (cocorosie - la maison de mon reve - 02 - by your side.mp3)
original disc pos #0 + 17979 (17979) = #17979/3:59.54
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17977 blocks [D: PIONEER DVD-RW DVR-K17RS]
2: TRM_AUDIO_NOPRE (cocorosie - la maison de mon reve - 04 - good friday.mp3)
original disc pos #0 + 19738 (19738) = #19738/4:23.13
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19736 blocks [D: PIONEER DVD-RW DVR-K17RS]
3: TRM_AUDIO_NOPRE (cocorosie - la maison de mon reve - 05 - not for sale.mp3)
original disc pos #0 + 5993 (5993) = #5993/1:19.68
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 5991 blocks [D: PIONEER DVD-RW DVR-K17RS]
4: TRM_AUDIO_NOPRE (cocorosie - la maison de mon reve - 06 - tahiti rain song.mp3)
original disc pos #0 + 16269 (16269) = #16269/3:36.69
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16267 blocks [D: PIONEER DVD-RW DVR-K17RS]
5: TRM_AUDIO_NOPRE (cocorosie - la maison de mon reve - 07 - candy land.mp3)
original disc pos #0 + 13220 (13220) = #13220/2:56.20
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13218 blocks [D: PIONEER DVD-RW DVR-K17RS]
6: TRM_AUDIO_NOPRE (cocorosie - la maison de mon reve - 09 - west side.mp3)
original disc pos #0 + 6363 (6363) = #6363/1:24.63
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 6361 blocks [D: PIONEER DVD-RW DVR-K17RS]
7: TRM_AUDIO_NOPRE (Cocorosie - La Maison De Mon Reve - 10 - Madonna.mp3)
original disc pos #0 + 17201 (17201) = #17201/3:49.26
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17199 blocks [D: PIONEER DVD-RW DVR-K17RS]
8: TRM_AUDIO_NOPRE (cocorosie - la maison de mon reve - 11 - hatian love songs.mp3)
original disc pos #0 + 22193 (22193) = #22193/4:55.68
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22191 blocks [D: PIONEER DVD-RW DVR-K17RS]
9: TRM_AUDIO_NOPRE (cocorosie - la maison de mon reve - 12 - lyla.mp3)
original disc pos #0 + 18312 (18312) = #18312/4:4.12
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18310 blocks [D: PIONEER DVD-RW DVR-K17RS]
10: TRM_AUDIO_NOPRE (Cocorosie - Noah's Ark - 04 - Bear Hides And Buffalo.mp3)
original disc pos #0 + 19055 (19055) = #19055/4:14.5
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19053 blocks [D: PIONEER DVD-RW DVR-K17RS]
11: TRM_AUDIO_NOPRE (Cocorosie - The Adventures Of Ghosthorse And Stillborn - 11 - Girl And The Geese.mp3)
original disc pos #0 + 3667 (3667) = #3667/0:48.67
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 3665 blocks [D: PIONEER DVD-RW DVR-K17RS]
12: TRM_AUDIO_NOPRE (030 - 01 - samba da Benção - Bebel Gilberto.mp3)
original disc pos #0 + 21552 (21552) = #21552/4:47.27
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21550 blocks [D: PIONEER DVD-RW DVR-K17RS]
13: TRM_AUDIO_NOPRE (031 - 02 - Track 2 - Bebel Gilberto.mp3)
original disc pos #0 + 20800 (20800) = #20800/4:37.25
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20798 blocks [D: PIONEER DVD-RW DVR-K17RS]
14: TRM_AUDIO_NOPRE (032 - 03 - Track 3 - Bebel Gilberto.mp3)
original disc pos #0 + 13626 (13626) = #13626/3:1.51
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13624 blocks [D: PIONEER DVD-RW DVR-K17RS]
15: TRM_AUDIO_NOPRE (033 - 04 - Track 4 - Bebel Gilberto.mp3)
original disc pos #0 + 14309 (14309) = #14309/3:10.59
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14307 blocks [D: PIONEER DVD-RW DVR-K17RS]
16: TRM_AUDIO_NOPRE (034 - 05 - Track 5 - Bebel Gilberto.mp3)
original disc pos #0 + 19282 (19282) = #19282/4:17.7
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19280 blocks [D: PIONEER DVD-RW DVR-K17RS]
17: TRM_AUDIO_NOPRE (035 - 06 - Track 6 - Bebel Gilberto.mp3)
original disc pos #0 + 18363 (18363) = #18363/4:4.63
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18361 blocks [D: PIONEER DVD-RW DVR-K17RS]
18: TRM_AUDIO_NOPRE (036 - 07 - Track 7 - Bebel Gilberto.mp3)
original disc pos #0 + 15939 (15939) = #15939/3:32.39
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15937 blocks [D: PIONEER DVD-RW DVR-K17RS]
19: TRM_AUDIO_NOPRE (037 - 08 - Track 8 - Bebel Gilberto.mp3)
original disc pos #0 + 10853 (10853) = #10853/2:24.53
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10851 blocks [D: PIONEER DVD-RW DVR-K17RS]
20: TRM_AUDIO_NOPRE (038 - 09 - Track 9 - Bebel Gilberto.mp3)
original disc pos #0 + 15506 (15506) = #15506/3:26.56
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15504 blocks [D: PIONEER DVD-RW DVR-K17RS]
21: TRM_AUDIO_NOPRE (039 - 11 - close your eyes - Bebel Gilberto.mp3)
original disc pos #0 + 19102 (19102) = #19102/4:14.52
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19100 blocks [D: PIONEER DVD-RW DVR-K17RS]
14:15:38 #11 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [D: PIONEER DVD-RW DVR-K17RS] for write in TAO
DAO infos:
MCN: "†††††† "
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 22: Idx 0 Idx 1 Next Trk
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 44532768, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 44532768 44885568 87172176, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 87172176 87524976 133948752, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 133948752 134301552 148397088, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 148397088 148749888 187014576, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 187014576 187367376 218460816, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 218460816 218813616 233779392, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 233779392 234132192 274588944, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 274588944 274941744 327139680, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 327139680 327492480 370562304, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 370562304 370915104 415732464, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 415732464 416085264 424710048, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 424710048 425062848 475753152, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 475753152 476105952 525027552, ISRC ""
15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 525027552 525380352 557428704, ISRC ""
16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 557428704 557781504 591436272, ISRC ""
17: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 591436272 591789072 637140336, ISRC ""
18: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 637140336 637493136 680682912, ISRC ""
19: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 680682912 681035712 718524240, ISRC ""
20: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 718524240 718877040 744403296, ISRC ""
21: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 744403296 744756096 781226208, ISRC ""
22: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 781226208 781579008 826506912, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x21 | 0 | 0 | 0x00
0 | 1 | 1 | 0x21 | 18784 | 0 | 0x00
18784 | 2 | 0 | 0x21 | 0 | 0 | 0x00
18934 | 2 | 1 | 0x21 | 17979 | 18934 | 0x00
36913 | 3 | 0 | 0x21 | 0 | 0 | 0x00
37063 | 3 | 1 | 0x21 | 19738 | 37063 | 0x00
56801 | 4 | 0 | 0x21 | 0 | 0 | 0x00
56951 | 4 | 1 | 0x21 | 5993 | 56951 | 0x00
62944 | 5 | 0 | 0x21 | 0 | 0 | 0x00
63094 | 5 | 1 | 0x21 | 16269 | 63094 | 0x00
79363 | 6 | 0 | 0x21 | 0 | 0 | 0x00
79513 | 6 | 1 | 0x21 | 13220 | 79513 | 0x00
92733 | 7 | 0 | 0x21 | 0 | 0 | 0x00
92883 | 7 | 1 | 0x21 | 6363 | 92883 | 0x00
99246 | 8 | 0 | 0x21 | 0 | 0 | 0x00
99396 | 8 | 1 | 0x21 | 17201 | 99396 | 0x00
116597 | 9 | 0 | 0x21 | 0 | 0 | 0x00
116747 | 9 | 1 | 0x21 | 22193 | 116747 | 0x00
138940 | 10 | 0 | 0x21 | 0 | 0 | 0x00
139090 | 10 | 1 | 0x21 | 18312 | 139090 | 0x00
157402 | 11 | 0 | 0x21 | 0 | 0 | 0x00
157552 | 11 | 1 | 0x21 | 19055 | 157552 | 0x00
176607 | 12 | 0 | 0x21 | 0 | 0 | 0x00
176757 | 12 | 1 | 0x21 | 3667 | 176757 | 0x00
180424 | 13 | 0 | 0x21 | 0 | 0 | 0x00
180574 | 13 | 1 | 0x21 | 21552 | 180574 | 0x00
202126 | 14 | 0 | 0x21 | 0 | 0 | 0x00
202276 | 14 | 1 | 0x21 | 20800 | 202276 | 0x00
223076 | 15 | 0 | 0x21 | 0 | 0 | 0x00
223226 | 15 | 1 | 0x21 | 13626 | 223226 | 0x00
236852 | 16 | 0 | 0x21 | 0 | 0 | 0x00
237002 | 16 | 1 | 0x21 | 14309 | 237002 | 0x00
251311 | 17 | 0 | 0x21 | 0 | 0 | 0x00
251461 | 17 | 1 | 0x21 | 19282 | 251461 | 0x00
270743 | 18 | 0 | 0x21 | 0 | 0 | 0x00
270893 | 18 | 1 | 0x21 | 18363 | 270893 | 0x00
289256 | 19 | 0 | 0x21 | 0 | 0 | 0x00
289406 | 19 | 1 | 0x21 | 15939 | 289406 | 0x00
305345 | 20 | 0 | 0x21 | 0 | 0 | 0x00
305495 | 20 | 1 | 0x21 | 10853 | 305495 | 0x00
316348 | 21 | 0 | 0x21 | 0 | 0 | 0x00
316498 | 21 | 1 | 0x21 | 15506 | 316498 | 0x00
332004 | 22 | 0 | 0x21 | 0 | 0 | 0x00
332154 | 22 | 1 | 0x21 | 19102 | 332154 | 0x00
351256 | lead-out | 1 | 0x01 | 0 | 0 | 0x00
14:15:38 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 1. Length: 18784 -> 18782.
14:15:38 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 2. Length: 17979 -> 17977.
14:15:38 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 3. Length: 19738 -> 19736.
14:15:38 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 4. Length: 5993 -> 5991.
14:15:38 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 5. Length: 16269 -> 16267.
14:15:38 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 6. Length: 13220 -> 13218.
14:15:38 #18 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 7. Length: 6363 -> 6361.
14:15:38 #19 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 8. Length: 17201 -> 17199.
14:15:38 #20 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 9. Length: 22193 -> 22191.
14:15:38 #21 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 10. Length: 18312 -> 18310.
14:15:38 #22 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 11. Length: 19055 -> 19053.
14:15:38 #23 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 12. Length: 3667 -> 3665.
14:15:38 #24 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 13. Length: 21552 -> 21550.
14:15:38 #25 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 14. Length: 20800 -> 20798.
14:15:38 #26 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 15. Length: 13626 -> 13624.
14:15:38 #27 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 16. Length: 14309 -> 14307.
14:15:38 #28 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 17. Length: 19282 -> 19280.
14:15:38 #29 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 18. Length: 18363 -> 18361.
14:15:38 #30 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 19. Length: 15939 -> 15937.
14:15:38 #31 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 20. Length: 10853 -> 10851.
14:15:38 #32 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 21. Length: 15506 -> 15504.
14:15:38 #33 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 22. Length: 19102 -> 19100.
14:15:38 #34 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
14:15:38 #35 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-No, small files-No (<64KB)
14:15:38 #36 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 24x (3 600 KB/s)
14:15:38 #37 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
14:15:39 #38 Text 0 File MMC.cpp, Line 22363
Set BUFE: Buffer underrun protection -> ON
14:15:39 #39 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
14:15:42 #40 Text 0 File Cdrdrv.cpp, Line 1352
14:15:42.453 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:52 #41 Text 0 File Cdrdrv.cpp, Line 1352
14:15:52.515 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:52 #42 Text 0 File Cdrdrv.cpp, Line 1352
14:15:52.765 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:52 #43 Text 0 File Cdrdrv.cpp, Line 1352
14:15:52.796 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:52 #44 Text 0 File Cdrdrv.cpp, Line 1352
14:15:52.828 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:52 #45 Text 0 File Cdrdrv.cpp, Line 1352
14:15:52.859 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:52 #46 Text 0 File Cdrdrv.cpp, Line 1352
14:15:52.890 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:52 #47 Text 0 File Cdrdrv.cpp, Line 1352
14:15:52.937 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:52 #48 Text 0 File Cdrdrv.cpp, Line 1352
14:15:52.968 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #49 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.015 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #50 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.046 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #51 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.078 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #52 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.125 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #53 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.140 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #54 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.187 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #55 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.218 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #56 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.250 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #57 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.296 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #58 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.328 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #59 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.375 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #60 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.406 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #61 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.437 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #62 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.484 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #63 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.515 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #64 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.546 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #65 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.609 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #66 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53 #67 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.656 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #68 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.687 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #69 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.734 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #70 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.750 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #71 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.796 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #72 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.828 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #73 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.859 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #74 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.906 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #75 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.937 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:53 #76 Text 0 File Cdrdrv.cpp, Line 1352
14:15:53.968 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #77 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.015 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #78 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.031 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #79 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.078 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #80 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.109 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #81 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.156 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #82 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.187 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #83 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.218 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #84 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.265 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #85 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.296 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #86 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.328 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #87 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.359 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #88 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.390 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #89 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.437 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #90 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.468 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #91 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.500 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #92 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.546 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #93 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.578 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #94 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.625 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #95 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.687 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #96 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.734 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #97 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.765 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #98 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.796 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #99 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.828 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #100 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.859 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #101 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.906 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #102 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.937 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:54 #103 Text 0 File Cdrdrv.cpp, Line 1352
14:15:54.968 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:55 #104 Text 0 File Cdrdrv.cpp, Line 1352
14:15:55.015 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:55 #105 Text 0 File Cdrdrv.cpp, Line 1352
14:15:55.046 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:55 #106 Text 0 File Cdrdrv.cpp, Line 1352
14:15:55.093 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:55 #107 Text 0 File Cdrdrv.cpp, Line 1352
14:15:55.109 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:55 #108 Text 0 File Cdrdrv.cpp, Line 1352
14:15:55.156 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:55 #109 Text 0 File Cdrdrv.cpp, Line 1352
14:15:55.187 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:55 #110 Text 0 File Cdrdrv.cpp, Line 1352
14:15:55.218 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #111 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.062 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #112 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.093 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #113 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.125 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #114 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.156 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #115 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.187 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #116 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.218 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #117 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.250 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #118 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.296 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #119 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.328 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #120 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.359 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #121 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.406 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #122 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.437 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #123 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.468 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #124 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.515 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #125 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.531 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #126 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.578 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #127 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.609 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #128 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.656 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #129 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.687 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #130 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.718 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #131 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.765 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #132 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.796 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #133 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.828 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #134 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.875 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #135 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.890 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #136 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.937 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:56 #137 Text 0 File Cdrdrv.cpp, Line 1352
14:15:56.968 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:57 #138 Text 0 File Cdrdrv.cpp, Line 1352
14:15:57.000 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:15:57 #139 Text 0 File Cdrdrv.cpp, Line 1352
14:15:57.046 - D: PIONEER DVD-RW DVR-K17RS : Queue again later
14:16:22 #140 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #18934
14:16:23 #141 Text 0 File MMC.cpp, Line 22363
14:16:55 #142 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #37063
14:16:56 #143 Text 0 File MMC.cpp, Line 22363
14:17:30 #144 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #56951
14:17:31 #145 Text 0 File MMC.cpp, Line 22363
14:17:46 #146 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #63094
14:17:46 #147 Text 0 File MMC.cpp, Line 22363
14:18:16 #148 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #79513
14:18:17 #149 Text 0 File MMC.cpp, Line 22363
14:18:44 #150 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #92883
14:18:45 #151 Text 0 File MMC.cpp, Line 22363
14:19:00 #152 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #99396
14:19:00 #153 Text 0 File MMC.cpp, Line 22363
14:19:25 #154 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #116747
14:19:26 #155 Text 0 File MMC.cpp, Line 22363
14:19:56 #156 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #139090
14:19:57 #157 Text 0 File MMC.cpp, Line 22363
14:20:24 #158 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #157552
14:20:25 #159 Text 0 File MMC.cpp, Line 22363
14:20:52 #160 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #176757
14:20:53 #161 Text 0 File MMC.cpp, Line 22363
14:21:06 #162 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #180574
14:21:07 #163 Text 0 File MMC.cpp, Line 22363
14:21:36 #164 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #202276
14:21:36 #165 Text 0 File MMC.cpp, Line 22363
14:22:02 #166 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #223226
14:22:03 #167 Text 0 File MMC.cpp, Line 22363
14:22:24 #168 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #237002
14:22:25 #169 Text 0 File MMC.cpp, Line 22363
14:22:46 #170 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #251461
14:22:47 #171 Text 0 File MMC.cpp, Line 22363
14:23:11 #172 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 17 (relocatable, no disc pos, no patch infos, orig at #0): write at #270893
14:23:12 #173 Text 0 File MMC.cpp, Line 22363
14:23:37 #174 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 18 (relocatable, no disc pos, no patch infos, orig at #0): write at #289406
14:23:38 #175 Text 0 File MMC.cpp, Line 22363
14:23:56 #176 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Firefox 2.0.0.15
  1. bonsoir,
    tu veux graver quoi sur quoi?
    1. salut,
      Graver de la musique (format mp3 sur mon disque), sur des cdr
      Tout se passait bien avant que je ne doive réinstaller un nouveau disque dur et donc tout le système d'exploitation (win xp).
      La gravure démarre bien, mais échoue systématiquement avant la fin.
      6 essais différents en tentant de passer en mode disque entier, ou plage par plage; rien n'y fait.
      Merci de ta réponse
    2. @gdpentesbonsoir
      Question stupide as-tu tenter de reduire ta vitesse de gravure?
  2. oui, j'ai tenté à une vitesse moindre, même résultat.
    penses tu que celà vienne du nero que j'utilise (version craquée) ?
    La cellule du graveur a l'air propre
    je pensais qu'avec la log, quelqu'un de calé pourrait savoir d'où ça vient. Ca ne donne rien ?
